It's possible, but not simple bolt-on. Miko K has done it on his highly modified Cutlass. - Yesterday
New member with 98 lumina
Did it make it to 200k? -
The booster is held on with a 1/4 turn lock. Make sure the locking tab isn’t holding it from rotating, (push/pull it into unlocked position.) then get a prybar on the master cylinder studs and rotate it off. It’s so simple it’s stupid. Just an odd ball design.
