  2. 55trucker
    89 olds swaybar
  3. sadolboy48
    89 olds swaybar
  4. Yesterday
  5. Psych0matt
  6. rich_e777
    89 olds swaybar
  7. 94 olds vert
  8. 55trucker
    89 olds swaybar
  9. Runs rough. New coils plugs wires after hot.
  10. Raffaelli
    89 olds swaybar
  11. sadolboy48
    89 olds swaybar
  12. sadolboy48
    89 olds swaybar
  13. Bake82
    89 olds swaybar
  14. sadolboy48
    89 olds swaybar
  15. sadolboy48
    89 olds swaybar
  16. 94 olds vert
    89 olds swaybar
  17. I have an 89 oldsmobile cutlass supreme 3.1 my front swaybar broke on the passengers side, not inlinks, it doesn't have any, the whole bar broke. Been looking everywhere for some kind of replacement. Just wondering if anyone knows any kind of other car that I can use one from because I can't seem to find any. Never seen a whole sawybar break but sure didn't think that it would be so hard to find one. The ones I can find are either for earlier or later models that do have inlinks and they won't fit.
  18. Last week
  19. Thanks! Looks like they both use the same fcs rear shock/strut assembly according to rockauto. I'll definitely keep in mind looking into springs as well.
  20. Another on-line resources for checking part compatibility is a recycling yard search engine site called car-part.com. The search results can be set to include "All Interchange Choices", so that the search results include vehicles with parts that fit your vehicle Or you could call a recycling yard and ask about interchange options.
  21. I personally cannot say, though my usual method is to go on Rockauto and look up both vehicles with a more common strut, KYB, Monroe whatever and see if the part numbers match, if those more common struts are the same I'd say theres a good chance the Bilstiens fit. You many want to change springs as well as I'd imagine Buick springs may be made for a different ride height and for sure will be softer.
  22. I'm looking at getting new rear shocks and struts for my 2007 Buick Lacrosse, and I noticed bilstein makes struts and shocks for the same gen Impala. I was wondering if anyone knows if they would bolt up without any modification. If not, does anyone have any recommendations on something specifically for the Lacrosse?
  23. Earlier
  24. Greetings form Peru justa wan to share my new preservation project with the community. it's a legitimate 1991 OLSDMOBILE CUTLASS SUPREME INTERNATIONAL SERIES COUPE ( X-Code 3.4L DOHC TWIN Dual Cam) with only 25,857 original miles Here is a crazy part of its history: Someone in the past installed a 3rd-generation LPG system on it, which caused it to stop running back in the day. Because of that mistake, the car was left sitting for decades, sleeping like a time capsule! A blessing in disguise for me. Everything from the LPG system has been removed from the engine bay, except for the 16-gallon tank in the trunk and the exterior filler valve, which I will remove and patch later. The great news is that the engine is finally up and running again, and it sounds great! The interior is full Burgundy leather with the premium AQ9 bucket seats, and the green digital cluster works perfectly. Right now, I'm doing a complete brake overhaul (the front calipers were seized) and getting ready for a full fluid flush. New water pump and mechanical thermostat are going in next. My approach is mechanics first: make it move, shift, and brake safely, then deal with the bodywork. Glad to be here, and I'd love to hear your thoughts, technical tips, and recommendations for bringing this 90s unicorn back to life! WhatsApp Video 2026-.mp4 WhatsApp Video 2026-06-28 .mp4
  25. 94 olds vert
  26. Amanita
  27. carkhz316
    LS4 swap begins
  28. 55trucker
    LS4 swap begins
  29. carkhz316
    LS4 swap begins
