  2. Today
  3. The booster is held on with a 1/4 turn lock. Make sure the locking tab isn’t holding it from rotating, (push/pull it into unlocked position.) then get a prybar on the master cylinder studs and rotate it off. It’s so simple it’s stupid. Just an odd ball design.
  4. My father owns a 94 cutlass supreme convertible and its brake booster has failed. Everywhere i look for steps to replace the booster mentions 4 bolts holding the booster from inside the firewall, however, when I go to look, no bolts are to be found. When I look at the new booster, it seems to lock into place using grooves and some kind of locking bar. Nothing I do really does anything to get this booster to move and I am stumped on how to progress. The coter pin is out and the pedal disconnected. The master cylinder and abs contraption is off and out of the way. Theoretically, it should pop right out, yet it holds firm. Any help would be greatly appreciated! Thank you in advance.
  5. Last week
  6. Hey everyone, im currently looking for a couple of trim pieces for my 2002 buick regal. Im looking at getting the passenger door trim molding (exterior) and the rear deck seat belt cover (pic attached) willing to buy a whole door if need be
  7. GnatGoSplat
    Rust free rotors?
  8. 94 olds vert
    Rust free rotors?
  9. rich_e777
    Rust free rotors?
  10. Jscott
    Sunroof help again.
  11. Earlier
  12. Black92GS
  13. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  14. cutlassman
  15. bluecalais79
  16. GnatGoSplat
    Rust free rotors?
  17. GnatGoSplat
    Wiring Differences 88-90?
  18. Dude.... I own this car now.... Mine is exactly how your describing yours... From florida originally but Ohio car, hail damage, salvage title, center line wheels and the black hood and spoiler... Bro I have your car lol.
  19. Last American Indian
    Best handling factory w body?
  20. SuperBuick
  21. bluecalais79
  22. jiggity76
    How to clean my Cutlass.
  23. rich_e777
    Rust free rotors?
  24. Black92GS
    TOM ( SUPERBUICK)
  25. GnatGoSplat
    TOM ( SUPERBUICK)
  26. SuperBuick
    TOM ( SUPERBUICK)
  27. GnatGoSplat
    Should I go back to stock?
  28. Black92GS
  29. GnatGoSplat
