  2. 55trucker
    Wheel fit
  3. rich_e777
    Wheel fit
  4. Psych0matt
    Wheel fit
  5. It shouldn't be much lower than it was, but I definitely should get it aligned again. It's hard to tell since I had them all the way apart. I should have measured the wheel gap and/or fender height from the ground before and after, but I didn't for some reason.
  6. pwmin
    Wheel fit
  7. I'm seeing -.65 on both front wheels as the finished setting by the shop, that's a little more than negative half a degree. You're at just under 1 degree negative on the rears. I personally wouldn't adjust those at all, but those settings were done 2 years ago, you've had the front end apart & the car now sits lower, that will alter those earlier settings to some degree. Lowering the car will induce more negative camber.
  8. I'm at just under - 1. I raised it a little more.
  9. Go4DaMo
    Wheel fit
  10. Go4DaMo
    Luminac
    Unsubscribe
  11. Go4DaMo
    1st Gen W body 14" wheels?
  12. Yesterday
  13. I do, so I'll have to check later and reference my alignment printout.
  14. I don't have a 2nd gen GM service manual so I do not know what the factory set the camber to.
  15. I can't recall, but it's close to stock. I think I should probably be able to go more negative without issue.
  16. You could dial in a little more negative camber on the fronts....do you know what the current setting is? One doesn't want to go *stupid* dramatic with negative.
  17. Gotcha, yes they are only single adjustable (rebound). Stiffening them up seemed to help in the past when the rears would do that, but could have just been in my head. I would go lower if I could, but they would hit a lot because of how close the tire is to the outside of the fender. That's what I get for living the "stance" life. I'll have to make due with the shocks I have. I don't think there are any coilover options for these with double adjustable ones. I could probably make something work if I researched enough, though, but I am much happier with the ride now.
  18. You're getting contact with the fender when the spring compresses, the shocks if they are single acting they don't dampen when compressing...only when they rebound. If what you have is an acceptable ride (not bone jarring) & the ride height is where you want it (even tho the fender is close to the tire), then what I suggest is a double acting shock that provides dampening in both directions. Seeing as you have mounted coil-overs you may be able to find double acting shocks for that setup.
  19. I'm talking about the strut dampening adjustment.
  20. Don't know how one changes the spring rate of a coil, it's built into the springs particular design rating.
  21. Already did that. They need a little more suppression.
  22. Last week
  23. Stiffen them up? or raise the car slightly
  24. Psych0matt
    Coilover Spring Rates
    I'm running (iirc) 450 and 350 and it's pretty dang tight, but not super stiff on normal roads (so it does suck sometimes around here haha). I'm gonna look back and see if I can find if my memory is correct edit: close, 400 and 350
  25. So far, it rides better. I need stiffen them up a little because the tires scrub on bumps sometimes.
  26. 55trucker
    Brake upgrade completed
    The Ford rotor *hat* is shorter, the overall height of the Ford rotor is only 1/4" more than that of the W rotor. The Impala rotors bolt circle is 118mm (4.6"), the W rotor is 115mm & the Ford is 114.5mm (4.5"). The Ford rotors pad surface thickness is near identical to the W rotor thickness 1.040" vs Ford 1.101".
  27. GnatGoSplat
    Should I go back to stock?
  28. I have for 24 years used the nylon pad/blocks and have had no problem. I bought and installed the rubber pads with the 3-M adhesive after cleaning them while a new rack unit was being installed. They didn't stay in place so I bought the nylon pads which lifted the car back up to a nice stance. I did grease the ends of the leaf spring. I have zero complaints and have had the car for 27 years. I replaced them once and I bought an extra pair and should install them again.
