92Lumi reacted to a post in a topic: What can I swap into my '89 Grand Prix MEGATHREAD
92Lumi started following 90-94 Lumina Cluster Pinouts and 3.1 to 3.4 or 3.8 swap
92Lumi reacted to a post in a topic: What transmissions can interchange with the 1994 Cutlass Supreme with an LQ1?
Point is, you could drive it with the monoleaf still in place, and a functional rear suspension. You have no NEED to "drop" the car. I ask again...why are you trying to ruin the vehicle?
