I did watch the video and seen it. But on my regal there isn’t enough access to fit down that tool to loosen the cartridge nut. That’s why I am going to show everyone a video in here of it as I do it. I can do everything until that part when it comes to putting the tool down the strut tower to remove that nut I can’t fit it in there. -
The guy in the video in post #3 is using the same 10 inch long tool with the 4 roubd pins sticking out the buisness end. You should be seeing the same parts as shown in the video unless your 98 is different. - Today
according to my Buick shop manual everything I needed is in here, I know some tools are missing in this kit. When you can let me know which tool you’re referring too. -
You sure beyond a doubt that what you have there isn't missing one of the long collars to remove the cartridge retaining nut? I do not see it there, it's approx 13 maybe 14" long, it's THAT collar that slides down from the top inside past the bellows to the top of the knuckle to turn the cartridge nut. I can't show you what mine looks like as I'm not home right now. -
Here’s the kit I try to use. It was the official kit Buick service manual told me to use that dealerships used back then to service the cartridges. -
I will show a video on here when I begin to do it again. And when I come to the part where the spanner nut and cartridge tool won’t fit down in the strut tower I’ll show that part. I was able to move the nut with the impact. I was able to remove the rubber mount too. After that I was able to screw the cartridge removal bar onto the top of cartridge in the tower and I was able to compress the cartridge down with that tool. But I couldn’t fit the spanner nut to loosen the cartridge. It’s complicated to explain so I will make the video. -
jiggity76 reacted to a post in a topic: TRW Keyless Entry module
White93z34 reacted to a post in a topic: TRW Keyless Entry module
architect reacted to a post in a topic: TRW Keyless Entry module
Please elaborate.....neither the bottom spring seat nor the upper spring seat are fastened to the knuckle, the lower seat, the spring, the upper seat are held in position by the force of the compressed spring against the upper & lower seats. The retaining nut at the top of the shock piston working against the rubber mount keeps everything together. -
I have that tool it wasn’t included in the kit I got off Walmart. So I had to buy it off eBay. I had to send the kit back when I wasn’t able to remove the cartridge. The seat is fastened to the top of the knuckle so I couldn’t fit the spanner nut tool down into the tower to remove the cartridge nut. There wasn’t even access to fit that tool you circled to keep the strut elevated from moving. I need to correct a video showing everyone what I am having trouble with. So I can get this done asap. I would love to work on this myself. No one knows how to work on these cars around me. So I’ve been doing all the repairs myself and learning from people in these forums and on fb. -
