  1. Yesterday
  2. Last week
  3. Black92GS
    Intermittent A/C!
  4. crazyd
    Intermittent A/C!
  5. Black92GS
    Intermittent A/C!
  6. crazyd
    Intermittent A/C!
  7. Black92GS
    Intermittent A/C!
  8. crazyd
    Intermittent A/C!
  9. Earlier
  10. 55trucker
  11. cutlassman
  12. 55trucker
  13. cutlassman
  14. 55trucker
  15. Hey everyone, my 1992 Cutlass Supreme Convertible I’ve had since 2000 is dead. It hydrolocked. I did manage to get it to start a couple times for a few seconds, but there’s a horrible knock and coolant out of the dual exhaust. I’ve ripped it down to the block once, about 14 years ago and don’t feel like doing it again. I should junk the car…but you know how that goes. So, I’m looking for a remanufactured engine with a warranty that I’ll have a local shop install. Any recommendations on the best company to go with? Looking at S&K Engines….Accurate Engines…ATK via Jegs…let me know if you have any experience with a remanufactured engine, or a shop in the Southeast I could send it to.
  16. Black92GS
    Intermittent A/C!
  17. crazyd
    Intermittent A/C!
  18. I don't recall the space being restricted, but might have to get a breaker bar on there and a BFH (Big F-ing Hammer).
  19. DIY coilovers. There's no other readily available way.
  20. Black92GS
    Intermittent A/C!
  21. crazyd
    Intermittent A/C!
  22. Black92GS
    Intermittent A/C!
  23. crazyd
    Intermittent A/C!
  24. crazyd
    Intermittent A/C!
  25. Black92GS
    Intermittent A/C!
  26. crazyd
    Intermittent A/C!
  27. for shits and giggles i want sparks to fly when it drives it was a $500 car with 160k miles on it lmao i have no need for it besides body parts. i have no need to own a second one but i chose to because that’s what freedom is all about brother
  28. Point is, you could drive it with the monoleaf still in place, and a functional rear suspension. You have no NEED to "drop" the car. I ask again...why are you trying to ruin the vehicle?
