  2. Black92GS
    1st Gen W body 14" wheels?
  3. 55trucker
  4. Black92GS
  5. White93z34
  6. 55trucker
  7. Yesterday
  8. Last week
  9. Mach 5
    TGPForums.com Future
  10. I talked to the original owner Kevin a year after buying the car and he showed me old photos of it in Florida before it came up to ohio, guy definitely loved this car. Shame it's poptart crust now.
  11. Sway bars just fell off the frame not too long ago and one of the front wheels is pushed up farther than the other one right where he said the subframe cracked.... Rear driver side has a decent hole through the frame too. Was told it was completely unsafe to drive at this point so I only drive it here and there. Will probably drive it until it gives out completely or part out within next couple years.
  12. Earlier
  13. carkhz316
  14. GnatGoSplat
  15. GnatGoSplat
    LED 3rd brake light write up
  16. GnatGoSplat
  17. It's at around 151k right now, unfortunately with the frame rot probably won't make it much longer. I bought it at 135k so I had fun with it while I could.
  18. cutlassman
  19. Raffaelli
  20. jiggity76
  21. rich_e777
  22. Did it make it to 200k?
  23. Black92GS
    OIL LEAK - 1994 Cutlass LQ1
  24. White93z34
  25. Black92GS
  26. bluecalais79
  27. White93z34
  28. ReiSabre
  29. GnatGoSplat
