92Lumi reacted to a post in a topic: URGENT: 4T65-E/4T65E-HD Transmission swap/interchange question
Ok so I wanted to let everyone know in here I had no luck still replacing the front strut cartridges with the tool kit I got off eBay to replace these strut cartridges. My friend came over to help me work on my Regal to replace the strut cartridges. We found out the strut cartridges have been played around with the first time they were replaced before. Someone who worked on it years ago tried cutting the top strut tower because we found small cut marks along where the studs are for the strut tower mount. We also found out they replaced the top mount with an aftermarket mount. So that’s why the strut tower will not fit the spanner nut extension down into the tower to loosen the cartridge nut. We have to remove the whole strut and compress it to remove the cartridge. What a pain in the ass. - Yesterday
92Lumi reacted to a post in a topic: V8 engine swaps
1990 cutlass international
