  2. architect
    TRW Keyless Entry module
  3. Today
  4. Yesterday
  5. GnatGoSplat
  6. architect
  7. architect
  8. GnatGoSplat
  9. architect
  10. GnatGoSplat
  11. Last week
  12. architect
  13. This tool acts as a handle that screws onto the threads on the end of the strut. Once installed you can move the strut around so you can center the strut in the hole. On my 96 the strut shaft wanted to move in the direction of the motor. I had to use pieces of wood wedged between the inner-fender and the strut spring to center the strut shaft so the removal tool would fit down the hole to the nut. Without this positioning tool i could not have changed my front struts. The guy in that video did not have this tool.
  14. This tool in my kit was useless because it was too big to fit in the hole. Maybe this tool will work on your 98?
  15. After removing all of the upper strut mount retaining paraphernalia one makes use of that deep extension, it goes right down over the extended shock piston, at the top end is a square 1/2" drive ratchet opening, one turns the ratchet counterclockwise to undo the retaining nut below on the top end of the knuckle. I've never made use of the short extension at all seeing as it will not clear the shock piston that would be extended (assuming the shock cartridge still has gas pressure inside). If you need to insert the spreader down the shock tower opening first to keep the shock cartridge in loose alignment so as to remove it & reinstall it. The spreader is that wide mouth gray device. The small socket adapter at the upper right is the adapter one uses to both remove & install the shock piston retaining nut, one slides the adapter down over the nut, the short arm is for a ratchet to turn the nut, the opening in the centre is for the #50 torx bit that slips into the female torx thread on the end of the piston shaft. One holds the torx bit still while one turns the ratchet, this prevents the piston from turning inside the shock housing. But note that most aftermarket shock cartridge replacements no longer use that torx thread, you may find that the new shock has an Allen head thread on the end of the shock piston.
  16. This thread needs more pictures. The round business end of the 10 inch long tool is 2-1/4 inches in diameter. You can see from the picture that the factory nut is slightly wider at about 2-3/8 inches. So if the factory strut retainer nut can fit down the shaft (hole) so can the tool in my picture.
  17. I did watch the video and seen it. But on my regal there isn’t enough access to fit down that tool to loosen the cartridge nut. That’s why I am going to show everyone a video in here of it as I do it. I can do everything until that part when it comes to putting the tool down the strut tower to remove that nut I can’t fit it in there.
  18. The guy in the video in post #3 is using the same 10 inch long tool with the 4 roubd pins sticking out the buisness end. You should be seeing the same parts as shown in the video unless your 98 is different.
  19. This is the same kit i have and you need the strut retainer tool on the far left. That tool is 10 inches long and can reach deep enough to do the job. You can find these kits on ebay for less than $100 if you wait and watch for them.
  20. according to my Buick shop manual everything I needed is in here, I know some tools are missing in this kit. When you can let me know which tool you’re referring too.
  21. You sure beyond a doubt that what you have there isn't missing one of the long collars to remove the cartridge retaining nut? I do not see it there, it's approx 13 maybe 14" long, it's THAT collar that slides down from the top inside past the bellows to the top of the knuckle to turn the cartridge nut. I can't show you what mine looks like as I'm not home right now.
  22. Here’s the kit I try to use. It was the official kit Buick service manual told me to use that dealerships used back then to service the cartridges.
  23. I will show a video on here when I begin to do it again. And when I come to the part where the spanner nut and cartridge tool won’t fit down in the strut tower I’ll show that part. I was able to move the nut with the impact. I was able to remove the rubber mount too. After that I was able to screw the cartridge removal bar onto the top of cartridge in the tower and I was able to compress the cartridge down with that tool. But I couldn’t fit the spanner nut to loosen the cartridge. It’s complicated to explain so I will make the video.
  24. 94 olds vert
  25. architect
  26. gr_elvis
    93 Cutlass Supreme convertible top issue
  27. GnatGoSplat
  28. jiggity76
