92Lumi reacted to a post in a topic: LS Swap - L67 & OBDII n2 95 Cutlass Vert
92Lumi reacted to a post in a topic: Thinking about a... 94 LQ1 to S2 L36 (or L67) swap
92Lumi reacted to a post in a topic: 2.8-3.8swap
92Lumi reacted to a post in a topic: A high mileage LQ1 thread
92Lumi reacted to a post in a topic: 3.4 DOHC to L26 Swap - OBDI to OBD II
Point is, you could drive it with the monoleaf still in place, and a functional rear suspension. You have no NEED to "drop" the car. I ask again...why are you trying to ruin the vehicle?
