  2. This is a great educational video about these motors. You can skip forward to the appropriate section for any questions.
  3. Today
  4. Agreeing with 55 here. Those are reusable...I can send you a video of the process.
  5. Yesterday
  6. Red Menace
    Want to buy
  7. That item is no longer produced, finding a *new* replacement will be on the awkward side. They can be serviced, it's just a mechanical oil filled/spring loaded tensioner.
  8. do you know were i can found the timing belt tensioner for this car the motor is 3.4 lq1 am changing the timing belt but mine is crying oil i need a new on the part number is GM 24503860
  9. Last week
  10. It's dusty........but not rusty. Nice climate in Peru.
  11. That's awesome, I often wish my Cutlass could end up somewhere exotic and I could live vicariously through it.
  12. GnatGoSplat
  13. 4doors4flying
  14. Yep, that tracks. The 7727/7730 confusion trips up a lot of people because the guts and calibration family overlap, but the packaging and mounting are what matter in the W-body. For CuttyBawl’s case I’d still verify the MEM-CAL broadcast code before trusting any ADX/XDF combo, especially with a reman ECM sticker involved. For scanning only, the right data stream/mask matters more than the XDF, so if it’s truly a 1990 LH0 he should be looking at $88 stuff first, not just grabbing A109 because it “sort of connects.” For tuning, yeah, starting from $A1 makes sense if you know what you’re changing, but I wouldn’t send a first-timer down that rabbit hole until the idle fault is sorted mechanically. OBD1 will happily let you chase ghosts all weekend, ask me how I know.
  15. Earlier
  16. 99z34na
  17. Black92GS
  18. 99z34na
  19. 55trucker
  20. 99z34na
  21. 55trucker
  22. 99z34na
  23. 99z34na
  24. 99z34na
  25. Black92GS
  26. 55trucker
  27. Black92GS
  28. 99z34na
  29. 96RegalGS
  30. Black92GS
