LED 3rd brake light write up
GnatGoSplat started following New to me 1996 Grand Prix SE, need thoughts and LED 3rd brake light write up
New member with 98 lumina
If you can recall, did that rubber NOS piece have that molded dip in it or is the rubber pliable enough to make those curves? I`m looking to replace this on 3 cars and it looks like the same between 1st gen W sedans and coupes/verts. - Last week
Did it make it to 200k? -
My father owns a 94 cutlass supreme convertible and its brake booster has failed. Everywhere i look for steps to replace the booster mentions 4 bolts holding the booster from inside the firewall, however, when I go to look, no bolts are to be found. When I look at the new booster, it seems to lock into place using grooves and some kind of locking bar. Nothing I do really does anything to get this booster to move and I am stumped on how to progress. The coter pin is out and the pedal disconnected. The master cylinder and abs contraption is off and out of the way. Theoretically, it should pop right out, yet it holds firm. Any help would be greatly appreciated! Thank you in advance.
