  2. 89-W-Body-Regal
    Does anyone live in SPRINGFIELD, MISSOURI?
    Does anyone live near by Springfield, Missouri? They have a 88 regal and I need a part off it. I would really appreciate it if you can look for me if you are not far. It’s a one year design only and my 89 regal has it being the early 89. I would not know where to find it else where. It’s the hood latch bracket that is inside the car to open the hood. It’s not the cable itself. It’s the bracket that the handle goes on. I would need the handle and the bracket. For a photo pm me.
  3. Yesterday
  4. Black92GS
  5. Last week
  6. rich_e777
  7. rich_e777
  8. Black92GS
  9. Schurkey
  10. Schurkey
  11. rcLord510
  12. 55trucker
  13. rcLord510
  14. 55trucker
    ? how short are you?.....
  15. rich_e777
  16. crazyd
    Intermittent A/C!
  17. RareGMFan
    Rear View Mirrors
  18. Earlier
  19. rcLord510
    2g Grand Prix dash removal?
  20. 94 olds vert
  21. rich_e777
  22. rcLord510
  23. 94 olds vert
  24. rcLord510
  25. 94 olds vert
  26. Black92GS
    Rear View Mirrors
  27. rcLord510
  28. pwmin
    Rear View Mirrors
  29. rich_e777
