laura joined the community - Yesterday
Should I go back to stock?
RPE1992GPSE reacted to a post in a topic:
Coilover Spring Rates
I'm running (iirc) 450 and 350 and it's pretty dang tight, but not super stiff on normal roads (so it does suck sometimes around here haha). I'm gonna look back and see if I can find if my memory is correct edit: close, 400 and 350 -
So far, it rides better. I need stiffen them up a little because the tires scrub on bumps sometimes.
