  2. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  3. Today
  4. Jscott
    Sunroof help…
  5. Yesterday
  6. Psych0matt
  7. Last week
  8. bluecalais79
  9. Psych0matt
    Sunroof help…
  10. Jscott
    Sunroof help…
  11. So I was watching old motorweek episodes on the 1st gen W-Bodies, and grabbed some screen caps comparing the times motorweek got. I realize this isnt bible but its interesting nonetheless! Of note - the quad 4 manual cutlas was the fastest of all to 60, but had a lower trap speed than the TGP and Z34. Clearly the Quad 4/manual was a good choice for this car performance wise - and their commentary on handling was that it was excellent (the most praise of the four) The TGP had the quickest 1/4 mile time, but not trap speed. The video showed very little wheelspin which clearly aided it off the line. The Z34 5-speed had a ton of wheelspin and tire smoke which seems to have limited its 0-60, but its trap speed is by far the highest. Clearly without the wheelspin this would be the “fastest” w-body and demonstrates the best power to weight. The 90 STE turbo was painfully slow compared to the rest, and especially the TGP. Given that its the same powertrain and the coupes and sedans are negligibly different weight-wise, this was either on a very hot day, or they just didnt have a very fast example (maybe a “friday car”)
  12. Earlier
  13. Rough budget I’d expect $1000 for parts car $500 clutch (spec 2+/3+) $300 flywheel (buy pre cut down and balanced from Fiero Rog in the Fiero Facebook groups) $200 fluids (trans fluid, coolant, oil etc) $200 clutch/flywheel bolts (GM tty bolts are pricey) $100-200 passenger side axle this doesn’t include any fabrication costs and any other “while you’re in there” costs and assumes you are doing all of the labour I’m sure you can do it cheaper but id be budgeting up to $3,000 all said and done
  14. Hopefully you get a notification to see this since it's been so long but I'm thinking about trying this in the future once it's not my daily but do you have any idea how much it was to do this
  15. Black92GS
  16. mikeytcarter
  17. mikeytcarter
  18. Black92GS
    More or less, yes. What matters is where the voltage drop is occurring. If the voltage drop is only at the fuse box itself due to an undersized feed, but the battery is maintaining ~14 volts the entire time, then moving the lights to run directly off the battery will have a positive effect, since they will no longer be subject to the drops affecting the fuse box. However, if the voltage drop is due to the PCM briefly turning off the alternator, or the alternator not yet having caught up to the demand, that drop will be at the battery itself, so it effects everything in the vehicle. Moving the lights directly to the battery wouldn't have an effect there, since they would still be affected by the same drop. In the first video it occurred in conjunction with the AC compressor turning on, which I call normal operation for these cars. My 2000 Regal did that and my parents 97 Lumina always did the same thing. The 2nd video was harder to tell, but it seemingly always happening around the same speed when coasting down makes me think that's when the car is coming out of it's deceleration fuel cut off, and the alternator output is briefly being cut to make the transition back to the IAC smoother. Older vehicles didn't experience this in the same manner, as the alternators weren't controlled by the PCM. Newer vehicles with electronic throttle bodies don't seem to experience this either as the PCM has full control over the throttle itself. I really don't think there is an issue that needs solving. If you want to keep the headlights from showing the effects, you could look at switching to LEDs. The LED chips typically run at less than 12 volts, so they have a voltage regulator to keep things in check. This would prevent them from dimming whenever the vehicle voltage fluctuates slightly. Also, ignore what I was mentioning earlier about the ABS. The ABS kicking in will cause the lights to dim briefly due to the load, but after seeing the driving video, i don't think that's what's happening here.
  19. mikeytcarter
  20. mikeytcarter
  21. Black92GS
  22. primergray
  23. Black92GS
    I don't believe you have an issue that warrants any concern if i'm being honest. I couldn't see the dimming, but I did hear when it took place. What I think is happening there is this: As you're coasting down, the engine cuts fuel and is freewheeling. Once you drop below to a certain speed/RPM, it will switch back to feeding fuel and to the IAC for idle speed control. The PCM is likely cutting the alternator output momentarily at the same time to make the overall transition smoother and to prevent stalling, but this will also result in a drop from charging voltage to battery voltage and then back. Non PCM controlled alternators monitor the voltage and self regulate based on that. PCM controlled alternators have the PCM monitor the voltage and the draw, and can adjust the alternator output as required. It also means they can reduce or cut the output completely in certain states to prevent other issues. If the alternator output is completely cut momentarily, you will immediately drop from charging voltage to battery voltage and then back once the alternator ramps back up. Halogen lighting output and blower speed will change along with this voltage change.
  24. mikeytcarter
    Between the 6 and 7 seconds in this video you can see it if you zoom in. Unfortunately lots of light pollution from the other cars so kind of hard to spot 20251218_182451.mp4
  25. mikeytcarter
  26. Black92GS
  27. mikeytcarter
  28. Black92GS
  29. mikeytcarter
  30. primergray
