rich_e777 reacted to a post in a topic: `89 TGP joining the collection
Please elaborate.....neither the bottom spring seat nor the upper spring seat are fastened to the knuckle, the lower seat, the spring, the upper seat are held in position by the force of the compressed spring against the upper & lower seats. The retaining nut at the top of the shock piston working against the rubber mount keeps everything together. -
I have that tool it wasn’t included in the kit I got off Walmart. So I had to buy it off eBay. I had to send the kit back when I wasn’t able to remove the cartridge. The seat is fastened to the top of the knuckle so I couldn’t fit the spanner nut tool down into the tower to remove the cartridge nut. There wasn’t even access to fit that tool you circled to keep the strut elevated from moving. I need to correct a video showing everyone what I am having trouble with. So I can get this done asap. I would love to work on this myself. No one knows how to work on these cars around me. So I’ve been doing all the repairs myself and learning from people in these forums and on fb. - Last week
It’s been just a little over a year now since I got the Regal…so what better way to celebrate that than with some more recent pictures. Nothing much visually has changed except for the refinished wheels and new tires…which was a fairly large, yet subtle change on its own. My intent is to keep the car as stock as possible, and to keep it up to snuff mechanically to be used as a reliable, fair weather cruiser. And to shake things up…. This is the final picture I ever took of my 89 GS before it was parked for good in summer of 2008. -
245/50R16
Actually its been holding up great. I've got over 20k miles on the swap now over 2 years. Nothing major, a couple ripped cv boots which may be because they were junkyard sourced. I highly recommend adding a HTOB spacer. ZZP sells them for around $50. Sits behind the HTOB and moves it closer to the clutch by 1/4" for earlier engagement and longer life. Aside from engineering the trans mount, the hardest part is getting the clutch pedal mounted and situated. The pedal arm needs to be cut & welded into proper position as well. As far as the mount, the low-profile mount I fabbed up works great. Only modification I made was adding rubber bushings under the nuts at the bottom to further insulate the mount from the frame. On an aluminum subframe, it might have to be done a bit different. Might be able to drill two holes and bolt it in the same way, but I haven't been hands-on with an 04+ subframe so I can't say for sure. I'm not a fan of the modified 4T65E bracket method that requires tubular control arms as the mount sits outside the frame. An extra $650 that could be spent elsewhere. There really are half a dozen ways you could fab up a mount but I can say for sure the one I made does the job. 3/16 steel plate holds up well so far. I have also just finished taking the time to document the changes to the tune that are highly recommended for a manual swap: Idle speeds in-gear changed to match P/N as its going to be wired to be in D at all times now. ( I actually added a toggle switch to change between forcing it in D or P, since P is needed for a crank relearn procedure if you need it) DTC codes changed And finally zeroing out all the auto trans stuff:
Psych0matt replied to Black92GS's topic in New Member Introductions
Welcome (back)! somehow I never got out for long, but the last few years I haven't posted as much, been trying to check in more often -
Psych0matt replied to DaleCar_3's topic in New Member Introductions
I know I;m a bit late but do you have a sound clip? I'm happy with my setup but it still doesn't sound great, I've never heard an LQ1 sound great haha -
Chase?
MrMcTiller replied to GtpKo's topic in Powertrain
Awesome writeup! How's the 5 speed holding up? I've been wanting to do this swap in my 2004 Impala LS. Do you have any advice/recommendations for making the f23 mount? I have the aluminum subframe. Would it be the same mounting as yours? -
MrMcTiller joined the community
55trucker started following 1992 Grand Prix aftermarket suspension
gr_elvis started following 93 Cutlass Supreme convertible top issue
Why won't my top go all the way down on one side?
