  2. Today
  3. I just figured it out! Got the GXP brackets and calipers from NAPA. They cut the mounting part off and drilled/tapped new mounting holes.
  4. GnatGoSplat
    Luminac
    I so very much hate these cross-era mashup cars, but my retinas are burned so I thought I'd share. https://www.junkyardlife.com/2015/11/luminac-repurposed-1958-cadillac-fins.html
  5. I tried SSR ones. I think they're the same as the Trailblazer, but I'm not sure. It was the closest yet, but still not correct. Both of the holes on this bracket are 8 1/4 center to center. They're directly in line and the front brace is straight across. Not that that part really matters. I'm going to look at the Cardone catalog and see what I can find. I can ask them as well. Last resort I might take them off and see if NAPA can match them up. I did have my dad order GXP calipers with brackets from NAPA to his shop that I'm going to check out today, but I'm not very hopeful. Figured I'd give it a shot.
  6. Reminds me of the caliper brackets on my Trailblazer. There's two kinds at the front, which has two-piston calipers. The calipers are the same, but the brackets are different between the regular-wheelbase Trailblazer (GMC Envoy, with Saab and Isuzu versions also.) and the extended-wheelbase Trailblazer and clones. The extended-wheelbase vehicles got slightly larger rotors, so the bolt spacing on the brackets is a little different.
  7. Yesterday
  8. 55trucker
  9. GnatGoSplat
  10. Black92GS
  11. GnatGoSplat
  12. Black92GS
  13. GnatGoSplat
  14. rcLord510
  15. kielu84
    2001 Buick Regal Intermittent No Start
  16. Last week
  17. The search continues. Does not look like it will work to me. I'll follow up on any leads I can get.
  18. GnatGoSplat
  19. rcLord510
  20. rcLord510
  21. rcLord510
    Anyway to fit 6.5 speakers in my 5.25 speaker bracket
    i may be wrong, since thats a 1.5 gen, but on the 2nd gp its a plastic ring that brings the speakers out closer to the door, that can be removed and i have personally test fit 3 different 6.5 drivers that will fit with the window, as thats gonna be your biggest issue, so it definetly depends on magnet size with the driver, but i know on gp's a few different drivers will fit. if youre gonna be using a 2 way system, youll have to cut a hole for the tweater or make a pod for it up on the a-pillar
  22. Could be. I will look into it. I bought an SSR bracket and it's not correct, either. It's in between the 2 GMT800 ones. GMT900 won't work either.
  23. Turbocharged3800
    Mystery Caliper Bracket
    I swear that looks like a ferd pbr caliper bracket from the mustangs.
  24. GnatGoSplat
  25. Any idea what these could be from? Custom strut housings for my Monte to fit GXP brakes, but the caliper bracket is not from a GXP and I have no information on it. Tim sent me everything he had, but it's not in there. No clue who made these strut housings back in the day. The Chevy dealer crossed it to a GXP bracket, but the bolt holes are about 8 1/4" apart instead of 5-ish for 2G W-bodies. Small GMT800 brackets are too small but the larger ones are too big. I have one on order from an SSR, which should be in between sizes, but I'm not sure. It's a different Cardone number from either of the GMT800 ones, so hopefully it's different. It doesn't look the same, but as long as the holes line up. Last picture is of GXP caliper and bracket.
  26. Earlier
  27. I’ve driven a gen 1 with FE3, my gtp, a 05 monte ss, so I haven’t drive a 3rd gen, but I will say the 2nd gens are much nicer driving. I like the cs but the gtp handles better in a lot of ways, but it depends what you consider better handling. For better cornering, the cs wins, for traction, and squat when accelerating, my gtp wins in that. So I guess it largely all depends.
  28. I think youd have to do it by generation, as there are some significant changes by generation as well as intent (when you get to the later years there was more of a focus on handling handling vs the earlier focus on comfort handling). In addition, its important to consider that skidpad Gs do not equal handling. Ive driven race cars that would do an epic skidpad number but are so ill handling in transition/under braking/whatever, that they are virtually undriveable. I have the most experience with 1st gen w-bodies, and my vote there would be for the FE3 level Grand Prix coupe with the 245 wide tires. Though I suspect/wonder if the 1990 olds international with FE3 and the quad 4 would be the ultimate iteration for handling. Ive never driven one (almost nobody has) so I cant say definitively, hence my mention above of the 245 tire equipped GP. For gen 1.5, Im not sure. For the last generation, its most likely the 2008 GP GXP. The fact they fitted reverse stagger tires (and engineered the suspension to utilize this setup) tells me someone understood how to make an FWD car handle.
  29. 94 olds vert
    Best handling factory w body?
  30. Just wondering which factory w body was the best handler. My initial thought was the 04 grand prix gtp comp g which had a 0.81g skidpad rating. however after doing some more research I found that the 2002 oldsmobile intrigue GLS had a 0.84g skidpad rating just wondering from those who have owned many w bodies which one handled the best
