Rust free rotors?
Rust free rotors?
Don't know how important this was to the corrosion resistance, but I forgot to mention I primed mine with Rustoleum Cold Galvanizing Compound spray. It worked surprisingly well as a primer on bare metal. It never chipped, flaked, or peeled. I don't know if it's the same formula today as the one I used a couple decades ago. Photos looks like it's now a smooth gray primer appearance, but mine was a very sparkly shiny bright metallic silver color. Almost looked like fine very fine glitter. Still have the can and looks like it's the same can as the current product though, so who knows. - Today
Rust free rotors?
Rust free rotors?
Rust free rotors?
Mo. joined the community -
Best handling factory w body?
