  1. Yesterday
  2. carkhz316
  3. GnatGoSplat
  4. Last week
  5. GnatGoSplat
    LED 3rd brake light write up
  6. GnatGoSplat
  7. It's at around 151k right now, unfortunately with the frame rot probably won't make it much longer. I bought it at 135k so I had fun with it while I could.
  8. cutlassman
  9. Raffaelli
  10. jiggity76
  11. rich_e777
  12. Did it make it to 200k?
  13. Black92GS
    OIL LEAK - 1994 Cutlass LQ1
  14. White93z34
  15. Black92GS
  16. bluecalais79
  17. White93z34
  18. ReiSabre
  19. GnatGoSplat
  20. bluecalais79
  21. Earlier
  22. Picked up a 1994 Pontiac Grand Prix coupe a few months back for a good price. Im in the process of putting a new motor in it due to an oil pump failure. But I've been thinking about suspension and steering system modifications. There isn't anything available for the 1994 but there's a ton of support for 1997+. Due to differences with the control arms I figured that easiest way to retrofit would be to swap a subframe from a newer Grand Prix into my '94 but I'm not sure if that's possible. From looking up photos online The general shape and mounting position seems to be the same. I was just wondering if anyone's ever done this swap before to update the suspension and steering because I'm sure anything's better than the cartridge strip design in terms of performance.
  23. GnatGoSplat
    Sunroof help again.
  24. GnatGoSplat
  25. GnatGoSplat
    Should I go back to stock?
  26. rcLord510
    TGPForums.com Future
  27. LukeZ34
  28. bluecalais79
