I tried SSR ones. I think they're the same as the Trailblazer, but I'm not sure. It was the closest yet, but still not correct. Both of the holes on this bracket are 8 1/4 center to center. They're directly in line and the front brace is straight across. Not that that part really matters. I'm going to look at the Cardone catalog and see what I can find. I can ask them as well. Last resort I might take them off and see if NAPA can match them up. I did have my dad order GXP calipers with brackets from NAPA to his shop that I'm going to check out today, but I'm not very hopeful. Figured I'd give it a shot.
Mystery Caliper Bracket
Schurkey replied to pwmin's topic in Brakes/Suspension/Steering/Wheels/Tires
Reminds me of the caliper brackets on my Trailblazer. There's two kinds at the front, which has two-piston calipers. The calipers are the same, but the brackets are different between the regular-wheelbase Trailblazer (GMC Envoy, with Saab and Isuzu versions also.) and the extended-wheelbase Trailblazer and clones. The extended-wheelbase vehicles got slightly larger rotors, so the bolt spacing on the brackets is a little different. - Yesterday
GnatGoSplat reacted to a post in a topic: 2001 Buick Regal Intermittent No Start
Turbocharged3800 replied to pwmin's topic in Brakes/Suspension/Steering/Wheels/Tires
I swear that looks like a ferd pbr caliper bracket from the mustangs. -
Turbocharged3800 changed their profile photo
94 olds vert started following pwmin
