94 olds vert reacted to a post in a topic: Disabling the dimming function?
94 olds vert reacted to a post in a topic: Remanufactured Engine Recommendations
rcLord510 reacted to a post in a topic: Disabling the dimming function?
Mystery Caliper Bracket
Turbocharged3800 replied to pwmin's topic in Brakes/Suspension/Steering/Wheels/Tires
I swear that looks like a ferd pbr caliper bracket from the mustangs. -
Turbocharged3800 changed their profile photo
? how short are you?.....
