  1. Yesterday
  2. Another on-line resources for checking part compatibility is a recycling yard search engine site called car-part.com. The search results can be set to include "All Interchange Choices", so that the search results include vehicles with parts that fit your vehicle Or you could call a recycling yard and ask about interchange options.
  3. I personally cannot say, though my usual method is to go on Rockauto and look up both vehicles with a more common strut, KYB, Monroe whatever and see if the part numbers match, if those more common struts are the same I'd say theres a good chance the Bilstiens fit. You many want to change springs as well as I'd imagine Buick springs may be made for a different ride height and for sure will be softer.
  4. I'm looking at getting new rear shocks and struts for my 2007 Buick Lacrosse, and I noticed bilstein makes struts and shocks for the same gen Impala. I was wondering if anyone knows if they would bolt up without any modification. If not, does anyone have any recommendations on something specifically for the Lacrosse?
  5. Last week
  6. Earlier
  7. Greetings form Peru justa wan to share my new preservation project with the community. it's a legitimate 1991 OLSDMOBILE CUTLASS SUPREME INTERNATIONAL SERIES COUPE ( X-Code 3.4L DOHC TWIN Dual Cam) with only 25,857 original miles Here is a crazy part of its history: Someone in the past installed a 3rd-generation LPG system on it, which caused it to stop running back in the day. Because of that mistake, the car was left sitting for decades, sleeping like a time capsule! A blessing in disguise for me. Everything from the LPG system has been removed from the engine bay, except for the 16-gallon tank in the trunk and the exterior filler valve, which I will remove and patch later. The great news is that the engine is finally up and running again, and it sounds great! The interior is full Burgundy leather with the premium AQ9 bucket seats, and the green digital cluster works perfectly. Right now, I'm doing a complete brake overhaul (the front calipers were seized) and getting ready for a full fluid flush. New water pump and mechanical thermostat are going in next. My approach is mechanics first: make it move, shift, and brake safely, then deal with the bodywork. Glad to be here, and I'd love to hear your thoughts, technical tips, and recommendations for bringing this 90s unicorn back to life! WhatsApp Video 2026-.mp4 WhatsApp Video 2026-06-28 .mp4
  8. 94 olds vert
  9. Amanita
  10. carkhz316
    LS4 swap begins
  11. 55trucker
    LS4 swap begins
  12. carkhz316
    LS4 swap begins
  13. 55trucker
    Very rough idle
  14. Jscott
    Very rough idle
    Awesome
  15. 55trucker
    Very rough idle
  16. Last American Indian
    Lowering a W-body?
  17. Jscott
    Very rough idle
  18. Jscott
    Very rough idle
  19. 55trucker
    Very rough idle
  20. Jscott
    Very rough idle
  21. 55trucker
    Very rough idle
  22. Jscott
    Very rough idle
  23. 55trucker
    Very rough idle
  24. Jscott
    Very rough idle
    Great advice. Thank you.
  25. Last American Indian
    Lowering a W-body?
    So I will first start by recognizing that most will doubt what is presented here so I will attach links to some videos from Huibert Mees. He is a renowned suspension engineer, who has done chassis designs for Ford, Tesla & others. I refer back to my earlier post. Most think they know suspension, they think springs, struts, sway bars, (but never think of link ends) & maybe a few other things! And as such think they understand how to build a suspension. If the body rolls it must be springs or CG! So the first order of business; they lower the car’s CG by using a shorter spring! Terrible idea! Why? Even an inch or two down impacts the roll center negatively, while reducing the suspension travel! I am not comparing myself to Huibert Mees, but I have designed suspensions among many other mechanical devices for more than 50 years & have many patents. So I’m not trying to garner accolades. There are so many things to look at with a suspension, but if I pick just one thing to affect cornering & more specifically high speed cornering, it would be sway bars & their end link! Yet many ignore sway bars as a remedy. Even more so, most never consider their relative size vs end link size! If, I simply said to you, have you ever heard of Archimedes & his statement of "Give me a lever long enough and a fulcrum on which to place it, and I shall move the world." You most likely would say yes! Well to a degree this is your sway bar & end links! Do you honestly think a bar, aka lever, 4 feet or longer & ¾” or more in diameter; in some cases as much as 1 5/16”; can be effectively applied by a secondary lever that is more than 3x smaller!? In some cases like the solid aftermarket front bar of the W-body ll more than 4x smaller. If you did the section modulus of the two you would find the numbers even more staggering! Amanita, without seeing your setup I would be guessing, but by your pictures several things appear to be part of the cause, but all point possibly to two issues. The sway bar & weight distribution. It has been many years since I have worked on one of the first gen W-bodies. So please correct me where I am wrong. Doesn’t the front bar end point attach into a u bracket & rubber bushing? Similar to how the bar attaches to both sides of the frame? If so, the bar as the rectification point! I can explain how. The second is the weight distribution. These cars, as most should know, have a horrible weight distribution. Again there are ways to affect this if you want to put in the work. Last the rear leaf. This can be improved, but it will take work & if you can’t do that work I doubt it is worth it to you to pay to have it done. Last I will attach some pictures, sketches & links that may explain things better, especially the jacking force. The picture of you car is presenting your jacking issue.
  26. 55trucker
    Very rough idle
  27. Jscott
    Very rough idle
  28. Jscott
    Muffler options
    Thanks for the tip.
