  2. Black92GS
    Should I go back to stock?
  3. GnatGoSplat
  4. Black92GS
  5. bluecalais79
  6. 55trucker
    Rust free rotors?
  7. rich_e777
    Rust free rotors?
  8. Yesterday
  9. Black92GS
    Rust free rotors?
  10. GnatGoSplat
  11. 55trucker
    Rust free rotors?
  12. Black92GS
    Rust free rotors?
  13. rich_e777
  14. Looking to replace the brake rotors on my 1994 Cutlass and I would like to have some that didnt form rust in the non-contact parts. Has anyone used some of the premium coated rotors offered with any success?
  15. Last week
  16. 94 olds vert
  17. Check Amazon. Just search Buick logo door light. Some are stick on with double sided tape and a magnet style sensor to activate them one the door opens.
  18. Usually Indian for some reason. i did get on rock auto for your application, they did have one of the mounts in GM.
  19. I guess I'll give DEA a try... from what I been reading it's all the same Subpar quality Chinese stuff.
  20. GM if you can get them, anchor would be last resort. I just ordered a complete set of DEA mounts a couple days ago ago for my Lumina.
  21. Greetings everyone. I tried searching but didnt find anything about what engine/trans mounts to go with. I know the options are very limited Anchor, Westar and DEA but I'm hoping yall can recommend which one you all have had the better experience. The car is a 2000 Buick regal GS thanks.
  22. Psych0matt
    TOM ( SUPERBUICK)
  23. Psych0matt
  24. Hey Guys, I'm restoring my 1993 Olds Convertible. I'm having trouble sourcing new rubber for the seals on the windows, doors, and trunk. Any ideas? Thanks!
  25. GnatGoSplat
    TOM ( SUPERBUICK)
    Wow, that's awesome!
  26. architect
    Draining Gas Tank - 95 Regal
  27. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
  28. Amanita
    TOM ( SUPERBUICK)
    Damn, that's a rare one!
