Good point, I dont drive at night too much but might on occasions and didnt think of that. The interior lights are bright enough at night so I suppose I should be looking to add a switch for a rain/overcast mode in the circuit. New bulbs and clean lenses still don't provide sufficient light when its raining or heavy overcast skies during the daytime though. Its during times like this is when I want brighter cluster and HUD lights, not necessarily at night. The HUD is barely visible and both the Cutlass and Turbo Grand Prix instrument clusters are recessed a fair bit in and surrounded. So I`m really not trying to disable anything at all just add a switch in the right place. I buy Sylvania bulbs only, they make `em in Kentucky and come in every size needed. Ive yet to have one burn out.
rich_e777 reacted to a post in a topic: Disabling the dimming function?
rcLord510 reacted to a post in a topic: Disabling the dimming function?
? how short are you?.....
