  2. carkhz316
  3. Today
  4. GnatGoSplat
  5. Yesterday
  6. GnatGoSplat
    LED 3rd brake light write up
  7. GnatGoSplat
  8. It's at around 151k right now, unfortunately with the frame rot probably won't make it much longer. I bought it at 135k so I had fun with it while I could.
  9. cutlassman
  10. Last week
  11. Raffaelli
  12. jiggity76
  13. rich_e777
  14. Did it make it to 200k?
  15. Black92GS
    OIL LEAK - 1994 Cutlass LQ1
  16. White93z34
  17. Black92GS
  18. bluecalais79
  19. White93z34
  20. ReiSabre
  21. GnatGoSplat
  22. bluecalais79
  23. Picked up a 1994 Pontiac Grand Prix coupe a few months back for a good price. Im in the process of putting a new motor in it due to an oil pump failure. But I've been thinking about suspension and steering system modifications. There isn't anything available for the 1994 but there's a ton of support for 1997+. Due to differences with the control arms I figured that easiest way to retrofit would be to swap a subframe from a newer Grand Prix into my '94 but I'm not sure if that's possible. From looking up photos online The general shape and mounting position seems to be the same. I was just wondering if anyone's ever done this swap before to update the suspension and steering because I'm sure anything's better than the cartridge strip design in terms of performance.
  24. GnatGoSplat
    Sunroof help again.
  25. GnatGoSplat
  26. Earlier
  27. GnatGoSplat
    Should I go back to stock?
  28. rcLord510
    TGPForums.com Future
  29. LukeZ34
  30. bluecalais79
