  2. 55trucker
    Don't know if you want to do that...the dimmer is integral in the headlight assembly, if you *at the moment* are seeing the cluster lamps *dim* when you bring on the headlamps then push up the dimmer lever to all the way bright. In that position the cluster light won't change their brightness.
  3. rcLord510
  4. Today
  5. 55trucker
    ? how short are you?.....
  6. Yesterday
  7. rich_e777
  8. Last week
  9. crazyd
    Intermittent A/C!
  10. RareGMFan
    Rear View Mirrors
  11. rcLord510
    2g Grand Prix dash removal?
  12. 94 olds vert
  13. rich_e777
  14. rcLord510
  15. 94 olds vert
  16. rcLord510
  17. 94 olds vert
  18. Black92GS
    Rear View Mirrors
  19. rcLord510
  20. pwmin
    Rear View Mirrors
  21. rich_e777
  22. RareGMFan
    Rear View Mirrors
  23. Black92GS
    Rear View Mirrors
  24. RareGMFan
    Rear View Mirrors
  25. pwmin
    Rear View Mirrors
  26. GtpKo
  27. rcLord510
  28. pwmin
    Rear View Mirrors
  29. Earlier
  30. GnatGoSplat
