  2. I did a bit of digging on this a while ago and unfortunately if you want to change anything about the suspension rate in these cars now past what FE3 gives you'll either need to contact a spring shop or figure out how to fit coilovers on the car. There were custom coilover mounts available here but the last batch sold out years ago. I'm sure there are springs out there that fit the car and provide a stiffer rate than stock but as far as I'm aware nobody has come across ones that fit.
  3. Today
  4. I gotcha. Just was wondering if there was something beefier for the W-Body I should look for.
  5. The springs are not a *Chevy* thing....all 1st Gen W's with the FE3 got the stiffest coils available. What's under your Z34 is also under a GP with the FE3 suspension.
  6. Not lower. Just have the best/highest spring rating chevy offered.
  7. There are no longer aftermarket *performance* springs manufactured for the 1st gen W's, if you've got the FE3 suspension under the car then you've already got the stiffest springs available. I take it that you want lower the front to match the dropped rear's ride height?
  8. 1994 Lumina Z34. Already have the rear end taken care of, and I wanted to beef up the front. Anyone know of the firmest springs I can get for the front of that strut design? I think I read something a while ago about 1996 Monte Carlo 3.4 front springs would be it. Suggestions?
  9. cutlassman
  10. Burg91
    03 Century 3100 - P0401 Code
  11. Yesterday
  12. Jscott
    Sunroof help again.
  13. Jscott
    Wiper won’t stop running
  14. Psych0matt
    Sunroof help again.
  15. rich_e777
    I would`ve liked that badge to be illuminated on the door pillar with black powdercoated door handles/lockplate vs the vertical pillar handle design we got.
  16. rich_e777
  17. Ive been getting water collecting in the spare tire well in the TGP and havent been able to figure out where its coming from. Thanks for mentioning the sealer failure, I will take a closer look.
  18. 55trucker
    Sunroof help again.
  19. Psych0matt
    Sunroof help again.
  20. I had a buddy of mine take a look at my Lumina for the same issue, in the trunk opening and below the rear window. Seam sealer cracked and allowing water in. Also I can see it leaking/starting to rust underneath the taillights just below the rear bumper support. Seams of panels. Might want to look there. My body shop guy will probably sand blast it, reseal it, then paint.
  21. Jscott
    Sunroof help again.
  22. I'm putting together a comprehensive plan to stave off the rot out of the rear strut towers in my '88 GP SE 5-spd. Background Not sure how well known this is, or if this is a whole W-Body issue or something unique to the Gran Prix's, but this is what I've learned in my research. The factory seam sealer used on this generation was petroleum based, standard at the time, but over the years the petro chemicals leach out of the substrate, which creates micro-fractures in the sealer. These micro-fractures, through capillary action, soak up salt water and hold it tight up against body metal, thus accelerating body-rust in the exact locations the OEM seam sealer was meant to protect. Additionally, there's a void-pocket between the inner and outer sides of the strut towers themselves. Over time, condensation collects in those void pockets due to heating-cooling cycles and the resultant moisture has nowhere to go and thus sits in there and rots out the rear strut towers from the top-side down, while the seam sealer defect eats them from the bottom-side up. My Plan (Please Suggest Corrections) Drop the wheels and struts entirely. Power wash the wheel wells Wire wheel/brush the factory seam sealer away entirely Horizontal shelf where strut tower is spot-welded to the frame Vertical seams Circular seam where the strut mounting studs poke through. Spray wheel well side with Corroseal Use a 360 degree spray head to flood strut tower voids with Corroseal Allow 48hrs for Corrosel to fully react Spray Eastwood 2K Epoxy Primer. Apply from the wheel wells up Apply into the strut tower void from the trunk-side, down Wait 24-48hrs for primer to cure Apply 3M 08367 Urethane Seam Sealer to the same places in the strut tower that we'd removed the factory seam sealer from. Inject 3M 08852 Cavity Wax Plus into the strut tower void cavities accessible from the trunk side w/360 degree spray head Install a GM Buick "F-Bar", part 19417890, across the rear strut towers. Bead weld the "cups" to the "bar" for complete rigidity Unload the suspension by raising the rear of the car before installing the strut bar, so that it will be under tension immediately. That's my plan, it's entirely speculative based on a whole lot of research, so please let me know if you tink I'm going down a bad road, or if there's any avenues for improvement. From my personal research, this aside from catastrophic loss, this generation of Grand Prix's were more than likely to be scrapped out from this design flaw than anything else, so staving this off should help preserve my longevity, but please let me know what you think! Sincere Regards, AJM
  23. Psych0matt
    Sunroof help again.
  24. Last week
  25. Jscott
    Sunroof help…
  26. Jscott
    Sunroof help again.
  27. Psych0matt
    Sunroof help again.
  28. Hey guys, kind of sad to see this community fade over the years, but hopefully some of you have some thoughts on this. I bit the bullet and put a new engine in my ‘92 CS Convertible, 3.1L. Most of the top parts were transferred over to the new block. Old engine ran fine before, but blew out the LIM and hydrolocked. Runs and idles great now, but above say 30 mph I get sputtering/misfiring on acceleration under load. Any ideas? ICM and coil packs only have a few thousand miles on them. New plugs with engine install. Wires are almost new. Car sat for several months with 3/4 tank, Stabil added, but the fuel is about 10 months old. Swapped TPS. No difference. Vacuum looks good. Older fuel? Fuel filter? Bad injector(s)? MAP? I’m going to take it back to the mechanic if I can’t figure it out myself. IMG_7976.mov
  29. Jscott
