UA-65274002-1
Coolant Leak Again!
  • Please log in to reply
23 replies to this topic
#21 Nicutlass_Supremacy
Nicutlass_Supremacy
    Member
  • Members
  • PipPip
  • 127 posts
  • LocationMontevideo, Uruguay
Posted 04 April 2018 - 07:48 PM
sounds as tho you covered the bases,
is the rack causing you any sort of issue?
when you say *smooth* do you mean that as you turn the steering wheel in either direction there is a studder being fed back up thru the column?
When you are turning you hear this whining noise and you feel like you are doing to much force, and it´s the same if you turn right or left
#22 Galaxie500XL
Galaxie500XL
    Senior Member
  • Contributing Member
  • 2,913 posts
  • LocationKnoxville, Tennessee
Posted 04 April 2018 - 08:15 PM
I may be way off base here...but I'd probably replace the engine mounts.
galaxie500xl
1993 LT1 Corvette Coupe
1988 Camaro IROC-Z 5.7 TPI 5-speed
2015 Chevrolet Equinox LTZ
GONE to a new home... 1995 Cutlass DOHC Convertible, 3rd Quarter 2012 W-Body.com COTQ
#23 55trucker
55trucker
    Senior Member
  • Members
  • PipPipPipPip
  • 1,119 posts
  • LocationOshawa, Ontario
Posted 04 April 2018 - 09:18 PM
The pump does whine to a certain degree, it's part of the characteristics of the pump (Saginaw Type II) used on the 1st gen cars, clean fluid does help to keep this controlled, do NOT use trans fluid.
There also is no variable assist so the steering IS heavy when at low speed, my wife has trouble turning the steering wheel under these conditions, one definitely cannot use *one finger* to turn the wheel, unlike my sons 2nd gen GTP where one CAN use just one finger to turn the steering wheel due to the variable assist.
Unless the the vanes in the pump or the pressure relief valve spring (in the pump) has failed there's not much else that could cause a low pressure situation
Steve
LQ1 GP GT
#24 Imp558
Imp558
    Proud TransCelestialsexual
  • 5,308 posts
  • LocationErie PA.
Posted 04 April 2018 - 09:57 PM
The GS, at least in 1995 got a very light rack. I can turn the wheel with a finger easily. It's actually too light for my liking. The Regal rack feels nothing like it.
"If everything seems under control, you're not going fast enough"  - Mario Andretti
1996 Buick Regal L67/4T65E-HD swapped - 1995 Buick Regal GS - 1980 Dodge Sno-Commander - 1968 Empi Imp on '67 Pan - 2001 Chevrolet Express 3500
Her Stuff: 1996 SSEi - 2001 Monte Carlo SS
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
