Very rough idle
My suggestion to you is to not throw parts at the issue, get a proper scanner on the engine, do a live readout & note in particular what the a/f display is showing you.
A failed o2 sensor will only prevent the fuel system from going into closed loop. If the sensor HAD failed then something upstream caused it to.
A check engine light will also light up. A bad map will completely throw off the ECM;s ability to configure a proper air/fuel ratio, that will be seen on a scanner as well.
Another small item to look at is the wiring harness condition to the engine temp sensor, if it's faulty then that sensor cannot send the proper signal to the ECM to configure A/F ratio due to inaccurate information on the engine actual temp. That will be seen on a scanner as well.
The 3 vital sensors needed for the ECM to calculate proper A/F ratio when the engine starts are the MAP, IAT, ENG TEMP.
You're more than likely going to find yourself on ebay looking for one, everything in the market today is geared to OBD2.
Some older models would read OBD1 & OBD2 up to a given year depending on the plug in cartridge.
The interface for OBD1 was not a single standard plug, it varied on the vehicle manufacturer & so did the harness to the scanner.
The item I own is an OTC 4000 enhanced.
https://www.ebay.com/sch/i.html?_nkw=otc+monitor+4000+enhanced&_sacat=0&_from=R40&_trksid=p2334524.m570.l1311&_odkw=otc+monitor+4000&_sop=12
Ok, that sounds like what you have is a *code reader*, it's not a scanner.
A proper scanner is more advantageous to one. The scanner will clear that code, the scanner will run a diagnostic on all of the sensors in the system. It has *realtime* capabilities, as for the IAC relearn this scanner will go thru the steps needed.
Look on ebay for a used complete scanner kit, the replacement for the OTC 4000E was the OTC Genisys SPX system, a newer version, capable with both OBD1 & pretty much all OBD2 up to 2010 until the EVO replaced it.
Even if it sounds like a somewhat expensive initial outlay a scanner is a worthwhile tool to own.
