pwmin Posted Wednesday at 10:36 PM Report Posted Wednesday at 10:36 PM I have Rev9 coilovers on my 2001 GT. I have 0 pre-load, which helps, but they're still a little bouncy and harsh no matter what I set the damper setting to. I have ZZP coilovers on the red car and, while not perfect, they are much better. I'm trying to figure out what spring rate they are or if anyone knows what I should swap them out for? I'm also going to grab more collars so I can lock them together. They keep coming loose. They have a thin lock washer, but one of them broke. Quote
55trucker Posted Thursday at 11:34 AM Report Posted Thursday at 11:34 AM Hmmmmmm.......... the Rev9 supplier doesn't disclose the coil spring rates to the customer? is it safe to assume you're using the 97-04 Buick Regal coils? https://coiloverkits.com/collections/rev9-coilovers/products/buick-regal-coilovers-1997-2004-rev9-hyper-street-ii-32-way-adjustable Quote
pwmin Posted Thursday at 02:36 PM Author Report Posted Thursday at 02:36 PM 2 hours ago, 55trucker said: Hmmmmmm.......... the Rev9 supplier doesn't disclose the coil spring rates to the customer? is it safe to assume you're using the 97-04 Buick Regal coils? https://coiloverkits.com/collections/rev9-coilovers/products/buick-regal-coilovers-1997-2004-rev9-hyper-street-ii-32-way-adjustable Well, crap, I'm an idiot Spring Rate(FRONT): 8 kg/mm (448 lbs/inch) (8k) (Spring Rate(REAR): 5 kg/mm (280 lbs/inch) (5k) https://www.ebay.com/itm/363295804829 BC (from ZZP): 5k Front, 6k Rear ZZP: 6.6kg front spring rate, 6.6kg rear spring rate Looks like I'm going to switch the fronts out for probably 6k if I can find them in 200mmx62mm (7.87" x 2.44") and try that. I believe the other ones use 10" springs, but I'll have to measure the other car this weekend. Quote
55trucker Posted Thursday at 03:08 PM Report Posted Thursday at 03:08 PM The softer the spring one uses the stiffer the dampening that's needed to keep ones ride from *floating*. Are these Rev9 shocks single or double acting? pwmin 1 Quote
pwmin Posted Thursday at 03:27 PM Author Report Posted Thursday at 03:27 PM 32 Clicks of Rebound Force Adjustment (I'm assuming single) Quote
