josh Posted January 8 Report Posted January 8 I tried just about everything and still no brakes.changed master cylinder brake pads calipers and still no brakes.what did I do wrong or what else can I do? Quote
Bake82 Posted January 8 Report Posted January 8 Did you bench bleed the master cylinder? On another posted you can't bleed 1 caliper only - is the caliper installed on the correct side with the bleeder valve pointing up? Did you replace the brake hoses? Are you getting any fluid out of the caliper? Any leaks? Quote
Schurkey Posted Sunday at 10:06 AM Report Posted Sunday at 10:06 AM On 1/8/2025 at 3:54 AM, josh said: I tried just about everything and still no brakes.changed master cylinder brake pads calipers and still no brakes.what did I do wrong or what else can I do? WHAT VEHICLE??? Do you have a scan tool to bleed the ABS with? Quote
