89-W-Body-Regal Posted June 30, 2024 Report Posted June 30, 2024 (edited) I have a 1989 Buick Regal Custom 2.8L V-6. This is my first time replacing the front strut cartridge myself. I just bought the tools on eBay. I need to know, when you remove the strut cartridge, the dealer shop manual says, oil from strut tube using suction device. If the oil has to be removed how much oil has to be removed? Do you ever need to drain the oil with fresh oil? What type of oil do you use? Not motor oil? Sorry for the stupid questions, that’s my only issue I have replacing these. I want to know how much to keep in there and how much to remove. Here is the factory info from my Buick shop manual. Edited June 30, 2024 by 89-W-Body-Regal rich_e777 1 Quote
Schurkey Posted June 30, 2024 Report Posted June 30, 2024 The OEM strut has loose oil inside. You'd remove ALL of it to the best of your ability. The replacement cartridge is a different design, that doesn't need oil inside the housing. Remove the oil, drop the new cartridge into the housing, put it together just like the manual says. rich_e777 and White93z34 2 Quote
89-W-Body-Regal Posted June 30, 2024 Author Report Posted June 30, 2024 (edited) What do you think of this? I don’t know why the shop manual doesn’t say this. I’ve watched a video on YouTube where a guy doing one of these said to keep some oil in there because you have to coat the new cartridge 1/2. So he removed some and said if he had to put some back in you would do it with the suction. The guy mentioned the oil cools down the heat of the strut cartridge so it don’t overheat. Was he right ? I don’t know why the manual didn’t mention this. Don’t want it to overheat the cartridge. But that’s what I hear people done before over the years. Watch 5:40 to 7:35 Edited June 30, 2024 by 89-W-Body-Regal rich_e777 1 Quote
ron350 Posted June 30, 2024 Report Posted June 30, 2024 Procedure #8 says - oil from strut tube using suction device. The service manual just forgot to put REMOVE OR DISCONECT at the top of that list. 89-W-Body-Regal 1 Quote
89-W-Body-Regal Posted June 30, 2024 Author Report Posted June 30, 2024 (edited) 19 minutes ago, ron350 said: Procedure #8 says - oil from strut tube using suction device. The service manual just forgot to put REMOVE OR DISCONECT at the top of that list. Yeah I see that, none of that service info makes sense really with wording. The video was really helpful. But the guy was right about the oil? Edited June 30, 2024 by 89-W-Body-Regal Quote
ron350 Posted June 30, 2024 Report Posted June 30, 2024 Step #8 says remove the oil so i removed the oil when I replaced my cartridges. Do whatever you want I don't think it really matters. 89-W-Body-Regal and White93z34 2 Quote
Schurkey Posted June 30, 2024 Report Posted June 30, 2024 There ARE strut cartridges that when replaced, need some oil-bath. Apparently, the W-body ones don't. OR the service manual is wrong. Can you get access to a later-model-year manual? rich_e777 1 Quote
89-W-Body-Regal Posted June 15 Author Report Posted June 15 (edited) On 6/30/2024 at 7:58 PM, Schurkey said: There ARE strut cartridges that when replaced, need some oil-bath. Apparently, the W-body ones don't. OR the service manual is wrong. Can you get access to a later-model-year manual? Ok well I found out from another post from 2019 this is what strut I have. The seat is fastened to the top of the knuckle assembly. That is why I can’t install the tool inside down into the strut tower to remove the strut closure nut that is supposed to remove the cartridge because the seat is covering any access to fit the cartridge tool down into the strut tower. Do I need to remove the whole strut assembly? *The manual says do not service the strut unless the weight of the vehicle is on the suspension. But some shops have the wall mount spring compressors for that* Seat on top of the knuckle. actual knuckle that the cartridge fits into. Edited June 15 by 89-W-Body-Regal Quote
White93z34 Posted June 15 Report Posted June 15 These cars are different then most with how the front suspension works. The seat sits well below where the strut nut is it won't be in your way at all. I've had them get to the point where the strut and spring wants to kick to the side when the upper mount is removed, can get sketchy. There is another tool meant to fit inside to maintain order in the event of that situation. As for the oil, keep it, remove it. really makes no difference. Listen to your heart. rich_e777 1 Quote
89-W-Body-Regal Posted June 15 Author Report Posted June 15 (edited) 3 hours ago, White93z34 said: These cars are different then most with how the front suspension works. The seat sits well below where the strut nut is it won't be in your way at all. I've had them get to the point where the strut and spring wants to kick to the side when the upper mount is removed, can get sketchy. There is another tool meant to fit inside to maintain order in the event of that situation. As for the oil, keep it, remove it. really makes no difference. Listen to your heart. Which tool is that because when I’ve tried to use the strut service tool kit from the dealership that was for these cartridges according to my Buick shop manual. Here are the steps I took: let me know if i am missing anything because it’s my first time doing this and i was not successful. - First I removed the strut mounting plate with the 3 nuts. - Next I removed the top nut for the cartridge with an impact socket. The special socket and Torx socket didn’t work. I am assuming because it’s corrosive. It still came off with the impact the nut. - Then I removed the rubber strut mount bumper prying it off with a screw driver. - Next the service manual says to remove the jounce bumper (the little foam bumper)I didn’t see that on mine. That must have never been reinstalled when we had a shop done the cartilage years ago. - Next I tightened the strut extension bar onto the top of the strut cartridge where the nut goes on top of the shaft. The extension bar let me push down on the spring to compress it with the wheel on the ground. -I then removed that tool as soon as I compressed the cartridge down and it was tough because the cartridge would move side to side with that tool when I was trying to loosen it. When it came time to use that other extension bar with the closure nut socket on it to loosen the cartridge closure nut I couldn’t fit that bar down into the strut tower from the top because I had no access to fit it down into the tower hole. I think it’s because the black seat that is fastened to the top of the knuckle is covering the hole so it won’t let me access the closure nut to loosen the cartridge tool. I don’t know why but there is another dealer tool by Kent Moore to actually service the whole knuckle too. It says you need to remove the whole knuckle to use the spring compressor. In this video the guy makes it look easy. He just fits the cartridge tool down in the tower and out comes the cartridge. It wasn’t like that on my regal. So I stopped at the point where I couldn’t get the bar to fit down into the tower to remove the cartridge. PS. Thank you for the kind information about removing the oil that it’s only by choice not required to do so. Edited June 15 by 89-W-Body-Regal Quote
ron350 Posted June 16 Report Posted June 16 Please post some pictures or a video so we can see what is going wrong? 89-W-Body-Regal 1 Quote
89-W-Body-Regal Posted June 16 Author Report Posted June 16 (edited) Thank you definitely with keep you posted when I do again. I am going to get the tool again. I sent it back because I couldn’t use it but I’ll be getting another kit. Edited June 16 by 89-W-Body-Regal Quote
55trucker Posted June 16 Report Posted June 16 10 hours ago, 89-W-Body-Regal said: Which tool is that because when I’ve tried to use the strut service tool kit from the dealership that was for these cartridges according to my Buick shop manual. Here are the steps I took: let me know if i am missing anything because it’s my first time doing this and i was not successful. this is one suppliers kit. https://westerntool.com.au/wp-content/uploads/AT185.jpg Quote
White93z34 Posted June 16 Report Posted June 16 90% of the time the only special tool I use is the spanner nut tool that actually unscrews it from the cartridge. Like I said I've had it where as soon as you pull the upper mount the strut rod wants to go hard to one side or the other thats where this tool, circled comes in to help stabilize it while you work.. also obviously make sure you're on level ground. then you jam the spanner tool down over it and spin it out pull the strut cartridge, slam the new one in and tighten it back down. Quote
89-W-Body-Regal Posted June 25 Author Report Posted June 25 (edited) On 6/16/2025 at 8:29 AM, White93z34 said: 90% of the time the only special tool I use is the spanner nut tool that actually unscrews it from the cartridge. Like I said I've had it where as soon as you pull the upper mount the strut rod wants to go hard to one side or the other thats where this tool, circled comes in to help stabilize it while you work.. also obviously make sure you're on level ground. then you jam the spanner tool down over it and spin it out pull the strut cartridge, slam the new one in and tighten it back down. I have that tool it wasn’t included in the kit I got off Walmart. So I had to buy it off eBay. I had to send the kit back when I wasn’t able to remove the cartridge. The seat is fastened to the top of the knuckle so I couldn’t fit the spanner nut tool down into the tower to remove the cartridge nut. There wasn’t even access to fit that tool you circled to keep the strut elevated from moving. I need to correct a video showing everyone what I am having trouble with. So I can get this done asap. I would love to work on this myself. No one knows how to work on these cars around me. So I’ve been doing all the repairs myself and learning from people in these forums and on fb. Edited June 25 by 89-W-Body-Regal Quote
55trucker Posted June 25 Report Posted June 25 41 minutes ago, 89-W-Body-Regal said: The seat is fastened to the top of the knuckle so I couldn’t fit the spanner nut tool down into the tower to remove the cartridge nut. There wasn’t even access to fit that tool you circled to keep the strut elevated from moving. . Please elaborate.....neither the bottom spring seat nor the upper spring seat are fastened to the knuckle, the lower seat, the spring, the upper seat are held in position by the force of the compressed spring against the upper & lower seats. The retaining nut at the top of the shock piston working against the rubber mount keeps everything together. Quote
89-W-Body-Regal Posted June 27 Author Report Posted June 27 (edited) On 6/25/2025 at 12:27 PM, 55trucker said: Please elaborate.....neither the bottom spring seat nor the upper spring seat are fastened to the knuckle, the lower seat, the spring, the upper seat are held in position by the force of the compressed spring against the upper & lower seats. The retaining nut at the top of the shock piston working against the rubber mount keeps everything together. I will show a video on here when I begin to do it again. And when I come to the part where the spanner nut and cartridge tool won’t fit down in the strut tower I’ll show that part. I was able to move the nut with the impact. I was able to remove the rubber mount too. After that I was able to screw the cartridge removal bar onto the top of cartridge in the tower and I was able to compress the cartridge down with that tool. But I couldn’t fit the spanner nut to loosen the cartridge. It’s complicated to explain so I will make the video. Edited June 27 by 89-W-Body-Regal Quote
89-W-Body-Regal Posted June 27 Author Report Posted June 27 On 6/25/2025 at 12:27 PM, 55trucker said: Please elaborate.....neither the bottom spring seat nor the upper spring seat are fastened to the knuckle, the lower seat, the spring, the upper seat are held in position by the force of the compressed spring against the upper & lower seats. The retaining nut at the top of the shock piston working against the rubber mount keeps everything together. Here’s the kit I try to use. It was the official kit Buick service manual told me to use that dealerships used back then to service the cartridges. Quote
55trucker Posted June 27 Report Posted June 27 You sure beyond a doubt that what you have there isn't missing one of the long collars to remove the cartridge retaining nut? I do not see it there, it's approx 13 maybe 14" long, it's THAT collar that slides down from the top inside past the bellows to the top of the knuckle to turn the cartridge nut. I can't show you what mine looks like as I'm not home right now. Quote
89-W-Body-Regal Posted June 27 Author Report Posted June 27 9 hours ago, 55trucker said: You sure beyond a doubt that what you have there isn't missing one of the long collars to remove the cartridge retaining nut? I do not see it there, it's approx 13 maybe 14" long, it's THAT collar that slides down from the top inside past the bellows to the top of the knuckle to turn the cartridge nut. I can't show you what mine looks like as I'm not home right according to my Buick shop manual everything I needed is in here, I know some tools are missing in this kit. When you can let me know which tool you’re referring too. Quote
ron350 Posted June 27 Report Posted June 27 This is the same kit i have and you need the strut retainer tool on the far left. That tool is 10 inches long and can reach deep enough to do the job. You can find these kits on ebay for less than $100 if you wait and watch for them. Quote
89-W-Body-Regal Posted June 27 Author Report Posted June 27 (edited) 1 hour ago, ron350 said: This is the same kit i have and you need the strut retainer tool on the far left. That tool is 10 inches long and can reach deep enough to do the job. You can find these kits on ebay for less than $100 if you wait and watch for them. So that dealer tool that Buick said to use will not work? I see from this one it’s the newer one. The dealer one has that tool but it’s shorter it’s not 10 inch longer. What you do with the dealer tool is use a 1/2 ratchet and long extension. Edited June 27 by 89-W-Body-Regal Quote
ron350 Posted June 27 Report Posted June 27 The guy in the video in post #3 is using the same 10 inch long tool with the 4 roubd pins sticking out the buisness end. You should be seeing the same parts as shown in the video unless your 98 is different. Quote
89-W-Body-Regal Posted June 27 Author Report Posted June 27 52 minutes ago, ron350 said: The guy in the video in post #3 is using the same 10 inch long tool with the 4 roubd pins sticking out the buisness end. You should be seeing the same parts as shown in the video unless your 98 is different. I did watch the video and seen it. But on my regal there isn’t enough access to fit down that tool to loosen the cartridge nut. That’s why I am going to show everyone a video in here of it as I do it. I can do everything until that part when it comes to putting the tool down the strut tower to remove that nut I can’t fit it in there. Quote
