cracked front sway bar ???
Megavolt-380
The entire area where that issue has developed is due to corrosion. One can see the rot in the tube right there.....they ARE hollow, a common occurrence with the gen 2 front anti roll bars.
If you can find a new one I’d suggest you sandblast it and powder coat. Then pour some paintable rust converter inside and coat it all around. That should stop your issues. I’ve never seen that happen before myself on any vehicle either.
Edited by GTP091
  • 2 months later...
Post is a little old, but I just swapped out my front sway bar with a solid 33mm one from ZZP about a month ago.  My stock bar was broke at the end (see image).  ZZP one is way beefier.
  • Thanks 1
