95DropCutty Posted March 16, 2021 Report Share Posted March 16, 2021 Came across a 95 cutlass supreme needs motor but found out it’s 2 different versions of this 3.1 motor and have vin number and wanted to know which 3.1 it has if anyone can help me 1G3WT35M8RD364302 Quote Link to comment Share on other sites More sharing options...
pontiac6ksteawd Posted March 16, 2021 Report Share Posted March 16, 2021 (edited) So by 95, they had dropped the 3.1, and replaced it for the 3100. The 3400 is also a viable option. You just have to determine which engine is correct for your application. The intake and head gaskets were a problem for the 3100/3400, so just watch out for that. You could also drop in a 3500 from the 2005-2007 Buick Rendezvous (and others). Much more reliable engine, and more power, with better fuel mileage. Check out MilzyMotorsports. It does require some fabrication, but its well worth it at the end of the day. https://www.milzymotorsports.com/3500-swap/?fbclid=IwAR1izJ-OoeYiIlP0rugtBRjXYpJe5X3xnzgjZKCb_0HUw7KKG9clOYTm7Tg He even sells an adapter kit to drop a L67 supercharger on the LX9 Edited March 16, 2021 by pontiac6ksteawd Quote Link to comment Share on other sites More sharing options...
rich_e777 Posted March 16, 2021 Report Share Posted March 16, 2021 Its the L82 3100 SFI, the Cutlass didn't get the redesigned 3100 found in later model GM cars but its basically the same engine. Go for a 3400 swap, its nearly identical but with better performance and minimal custom work. Milzy is da man! Quote Link to comment Share on other sites More sharing options...
