UA-65274002-1 Jump to content
GTP091
34 mm away bar
Does anybody need a 34mm sway bar from a 92 GP? I now have 3 and would like to send it on to someone who can use it rather than junk it. You pay shipping plus $20 cdn beer surcharge fee, includes mounts and isolators which should be replaced with poly.
Share this post
Link to post
Share on other sites
IIRC hes referring to the front sway bar found on the FE3 package. If you are trying to fit the thick rear sway bar from a 1.5 gen MonteLumina then you`ll need to swap to adjustable lat links and go coil over. The Z34 rear sway bar will push the wheel base out just a bit to far. It might install ok if it were bent inward about 2 inches but I didn have a torch or a strong enough ratcheting strap when the rear end was apart.
Share this post
Link to post
