runt Posted October 17, 2017 Report Share Posted October 17, 2017 On my 2007 GP in the past I've done the following: - New T-Stat. 195*F which is stock. - Bled cooling system with one of these: https://www.amazon.com/EPAuto-Radiator-Coolant-Filling-Funnel/dp/B01I40ZQWE/ref=sr_1_2?ie=UTF8&qid=1508244770&sr=8-2&keywords=radiator+funnel+bleed - Checked/re-checked coolant levels. My issue is this: the car gets up to temperature just fine. Once the T-Stat opens and I'm traveling at highway speeds (55mph or so) the temp on the gauge and inside the vehicle drops. It isn't cold per say but it's chilly enough that my windshield won't get fully cleaned off. My past W's were always HOT in the winter and this is lukewarm at best. During the summer the temps get to the middle mark and stay there even in extreme heat it rarely moves above the middle. Now I'm lucky to be on the first hash. (there are 4 bigs lines on the 04+ so I use the middle one as 'where it should be') This car doesn't have the metal cap so I'm thinking maybe replace that next. The only things done to the car are intake and I've removed the engine cover. Quote Link to comment Share on other sites More sharing options...
Grandprix1 Posted October 17, 2017 Report Share Posted October 17, 2017 Are you sure you bled it well enough? What coolant did you use? Was it the correct mixture? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
vipmiller803 Posted October 17, 2017 Report Share Posted October 17, 2017 Backflush heater core and rereplace tstat with different brand Quote Link to comment Share on other sites More sharing options...
runt Posted October 17, 2017 Author Report Share Posted October 17, 2017 I bled it twice last winter to be sure. Never did replace the coolant. Color was good at that time I was closer to 53k miles. I have a feeling the backflush is what it needs. Tstat was a good one but I'd do it anyway. Might just do a full flush, backfill and see what it does. Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted October 17, 2017 Report Share Posted October 17, 2017 Same issue here, Mine was fine until I flushed everything twice, I have a feeling I got a bad thermostat I didn't notice the heat thing until last night, but mine acts like it has some air until I rev it a bit which seems to open it until next cycle Quote Link to comment Share on other sites More sharing options...
94 olds vert Posted October 17, 2017 Report Share Posted October 17, 2017 (edited) My 2000 GTP had luke warm heat until I flushed the heatercore and replaced the coolant. I also replaced the T stat at that time. After that my heat was much hotter. Edited October 17, 2017 by 94 olds vert Quote Link to comment Share on other sites More sharing options...
Schurkey Posted October 24, 2017 Report Share Posted October 24, 2017 On my 2007 GP in the past I've done the following: - New T-Stat. 195*F which is stock. - Bled cooling system with one of these: https://www.amazon.com/EPAuto-Radiator-Coolant-Filling-Funnel/dp/B01I40ZQWE/ref=sr_1_2?ie=UTF8&qid=1508244770&sr=8-2&keywords=radiator+funnel+bleed - Checked/re-checked coolant levels. My issue is this: the car gets up to temperature just fine. Once the T-Stat opens and I'm traveling at highway speeds (55mph or so) the temp on the gauge and inside the vehicle drops. It isn't cold per say but it's chilly enough that my windshield won't get fully cleaned off. My past W's were always HOT in the winter and this is lukewarm at best. During the summer the temps get to the middle mark and stay there even in extreme heat it rarely moves above the middle. Now I'm lucky to be on the first hash. (there are 4 bigs lines on the 04+ so I use the middle one as 'where it should be') Backflush doesn't fix an engine that isn't warm enough. Backflush may improve coolant flow through the heater core or the radiator. Your engine isn't staying warm. Faulty thermostat. Are the cooling fans running? Quote Link to comment Share on other sites More sharing options...
runt Posted October 27, 2017 Author Report Share Posted October 27, 2017 Just replaced that last year but might warrant another one. Fans run as expected as far as I can tell. Quote Link to comment Share on other sites More sharing options...
White93z34 Posted October 27, 2017 Report Share Posted October 27, 2017 How much does the gauge drop off? Quote Link to comment Share on other sites More sharing options...
runt Posted November 1, 2017 Author Report Share Posted November 1, 2017 Drops almost 1/4. Gauge is at half when the car is "hot". When the t-stat opens (i'm assuming) it drops to nearly 1/4. Thinking I should flush the system and do another new t-stat. Quote Link to comment Share on other sites More sharing options...
Leadfoot Posted November 2, 2017 Report Share Posted November 2, 2017 Does it warm back up if you stop driving and let the car run while sitting still somewhere? My bet is on a thermostat. This is exactly what happened to me with a bad thermostat twice. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted November 2, 2017 Report Share Posted November 2, 2017 Did it do this when it had the old thermostat? I'm starting to wonder if maybe they gave you the wrong temperature stat. It will have the temperature stamped on the bottom of it Quote Link to comment Share on other sites More sharing options...
runt Posted November 4, 2017 Author Report Share Posted November 4, 2017 Can't say it warms after sitting but it will warm up if I hammer on it. Gonna do another t Stat and bleed the system down again. Havent had much time to check it out but it hasn't been cold either. Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
W30olds Posted November 5, 2017 Report Share Posted November 5, 2017 Air in the system maybe? Had the same issues when I replaced my radiator last year. Finally I bled the air out with the bleeder screws and that solved my issues. Good luck man! Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted November 13, 2017 Report Share Posted November 13, 2017 Replaced my thermostat tonight and made sure it was all topped up, will report back tomorrow. I've heard that parts store thermostats are kinda crappy for this engine so I ordered an ac delco for a few dollars more Galaxie500XL, runt, 94 olds vert and 1 other 4 Quote Link to comment Share on other sites More sharing options...
runt Posted November 14, 2017 Author Report Share Posted November 14, 2017 Been dealing with lack of heat in the house so haven't looked at this. Will keep that in mind before I talk to my mechanic buddy. Psych0matt 1 Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted November 14, 2017 Report Share Posted November 14, 2017 It helped marginally, but at this point I'm thinking my heater core is blocked up. I flushed everything up good in the spring, but I didn't do the heater core on its own so that's probably the issue now Quote Link to comment Share on other sites More sharing options...
W30olds Posted November 16, 2017 Report Share Posted November 16, 2017 It helped marginally, but at this point I'm thinking my heater core is blocked up. I flushed everything up good in the spring, but I didn't do the heater core on its own so that's probably the issue now Could maybe your blend door be stuck, or not working. Maybe the heater control valve? Quote Link to comment Share on other sites More sharing options...
Galaxie500XL Posted November 16, 2017 Report Share Posted November 16, 2017 Could maybe your blend door be stuck, or not working. Maybe the heater control valve? You reminded me of an issue I had on my '95 Cutlass that could apply here...I had a failed actuator that operated those doors on my old Cutlass, though mine failed open, which meant I had heat 100% of the time. Mine had the electronic climate control, so it had actuators, rather than using cables or vacuum to operate the doors. I honestly don't know what method is used on the 2007's...but if I were a betting man, I wouldn't be surprised if it uses actuators, too. I about died when I saw what new ones cost---nearly $250.00. After some patient searching, I found out that certain full sized GM pickup trucks used a different part number, but it was compatible. Found one in a junkyard, on a truck that someone had already removed the dash--cost me $5.00, and about 5 minutes of work removing it---and nearly 2 hours to properly install it on my Cutlass. primergray 1 Quote Link to comment Share on other sites More sharing options...
Galaxie500XL Posted November 16, 2017 Report Share Posted November 16, 2017 ...AND...a couple of minutes with Google, and I think I have the answer.. 2007 Grand Prix uses actuators for the blend door. http://www.partstrain.com/store/details/Pontiac/Grand_Prix/Dorman/Heater_Blend_Door_Actuator/2007/RB604108.html?source=bngpla&utm_source=bing&utm_medium=cpc&utm_campaign=PTNBNG-SH-Brand%20Dorman&utm_term=1100006267481&utm_content=PTN-BNG-Brand-BR-Dorman Quote Link to comment Share on other sites More sharing options...
runt Posted November 17, 2017 Author Report Share Posted November 17, 2017 Something to keep in mind! Thanks! Sent from my Pixel XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted November 17, 2017 Report Share Posted November 17, 2017 I'll have to look at this too, although mine worked fine last winter (but that was before I flushed the radiator and cooling system) Quote Link to comment Share on other sites More sharing options...
Galaxie500XL Posted November 17, 2017 Report Share Posted November 17, 2017 IIRC, they fail most often after the battery has been disconnected...they go through their full range of motion, and generally fail by eating their internal gears. Psych0matt 1 Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted November 17, 2017 Report Share Posted November 17, 2017 don't think that's my issue, I get warm air at higher RPMs Quote Link to comment Share on other sites More sharing options...
runt Posted November 17, 2017 Author Report Share Posted November 17, 2017 don't think that's my issue, I get warm air at higher RPMs Same here. I'm sure, for me, it's either air or heater core needs a good flush. Quote Link to comment Share on other sites More sharing options...
