Canada4g63 Posted September 19, 2017 Report Share Posted September 19, 2017 Snyone ever put a,4t65e tran in one of the TGP's Quote Link to comment Share on other sites More sharing options...
Imp558 Posted September 19, 2017 Report Share Posted September 19, 2017 That would be easy mechanically, every other aspect of it would suck, like a whole lot of suck and a lot of tuning. You'd almost be better off running a TCI controller. Quote Link to comment Share on other sites More sharing options...
55trucker Posted September 19, 2017 Report Share Posted September 19, 2017 Yeah, the TGP pre-dates the 4T60E trans, but that doesn't mean all is lost..... you would need to reprogram the MEMCAL *chip* inside the casing. 1990 did not see the electronic transmissions but 1993 did where the *T* code LHO engines are concerned. Your engine is a *V* code LG5 which is basically an LHO with a lung bolted on. Your ECM case is the same case that is used in the 1993 W-body Lumina (1227727) which has the 3.1 LHO engine & the 4T60E trans. If you were serious on this you would need the wiring harness from needed car to splice into to do the conversion on yours. The ECM 16149396 which controls the DOHC engine would also work as it too was used with the 3.1 LHO in '93, Now I know that the 4T60E-HD would be doable because it was used in the OBDI cars, but I don't have enough info as to whether the OBDII 4T65E trans could be made backward compatible with an OBDI ECM. COPY the added link to keep in your files..it is getting hard to find http://web.archive.org/web/20070329054010/http://www.cruzers.com/~ludis/p4xref.html#1227749 Quote Link to comment Share on other sites More sharing options...
Heartbeat1991 Posted September 19, 2017 Report Share Posted September 19, 2017 Why would you want to do this? It's a lot of work and expense. Imp558 1 Quote Link to comment Share on other sites More sharing options...
Canada4g63 Posted September 22, 2017 Author Report Share Posted September 22, 2017 I might want to do this because sourcing a newer 4t65e trans is easier and you can have one build and be done with the trans Quote Link to comment Share on other sites More sharing options...
Heartbeat1991 Posted September 22, 2017 Report Share Posted September 22, 2017 Or just get your stock trans built and put it back in and be done. White93z34 1 Quote Link to comment Share on other sites More sharing options...
White93z34 Posted September 22, 2017 Report Share Posted September 22, 2017 I have a core TGP 4t60 that I'd GIVE away at this point Quote Link to comment Share on other sites More sharing options...
Dark Ride Posted September 23, 2017 Report Share Posted September 23, 2017 I have a 4T65e in my tgp. But it also is OBD II. Keep in mind the 4T65 can fail too. Unless you convert to OBD II, I don't think it can be done. Quote Link to comment Share on other sites More sharing options...
jman093 Posted September 26, 2017 Report Share Posted September 26, 2017 I have a core TGP 4t60 that I'd GIVE away at this point And I have a TGP with all its gears except 1st, 2nd, 4th, Neutral, Reverse, and converter lock-up. And use of its lone 3rd gear requires putting the shifter in neutral. Believe it or not, it's been my daily most of the time for the last few months, now that I finally got the awful, awful DMV to register the darn thing. Starts are sluggish, but it goes great down the highway in 3rd gear, shifter in neutral. You should buy it and put said transmission it. Quote Link to comment Share on other sites More sharing options...
mfewtrail Posted September 29, 2017 Report Share Posted September 29, 2017 A 65-E swap retaining OBD-1 is possible if you use a early 90'sISH diesel truck transmission controller. Read this and any subsequent threads started by the same author on that subject. https://www.a-body.net/forums/showthread.php?1589-Transmission-swap-about-to-start-440T4-gt-4T65E primergray 1 Quote Link to comment Share on other sites More sharing options...
