tonytoca_87 Posted May 21, 2017 Report Share Posted May 21, 2017 Hello everyone. So over the weekend i finished swapping the timing belt and all components. I even changed the tensioner pulley that is driven by the accessory belt. Car runs good and does not over heat. However theres a strange noise coming from the belt area and i cant figure what it is. Any thought or suggestions on where to start. Thanks, Tony. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted May 21, 2017 Report Share Posted May 21, 2017 Spray a little wd40 on the tensioner and idlers aI bet it goes away. tonytoca_87 1 Quote Link to comment Share on other sites More sharing options...
tonytoca_87 Posted May 21, 2017 Author Report Share Posted May 21, 2017 Ok i will try that. Thanks a ton. I was starting to think i screwed up somewhere down the line but the car runs fine. Spray a little wd40 on the tensioner and idlers aI bet it goes away. Quote Link to comment Share on other sites More sharing options...
tonytoca_87 Posted May 21, 2017 Author Report Share Posted May 21, 2017 Spray a little wd40 on the tensioner and idlers aI bet it goes away. Ok thanks will try that out. Quote Link to comment Share on other sites More sharing options...
tonytoca_87 Posted May 21, 2017 Author Report Share Posted May 21, 2017 I took off the serpentine belt and lubricated the pullyley. So far no noise. Hopefully that solves the issue. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted May 21, 2017 Report Share Posted May 21, 2017 It'll be back, Rockauto should have all the pulleys for cheap. I try to keep a whole set here so I never have to pay three times as much locally. tonytoca_87 1 Quote Link to comment Share on other sites More sharing options...
tonytoca_87 Posted May 24, 2017 Author Report Share Posted May 24, 2017 It'll be back, Rockauto should have all the pulleys for cheap. I try to keep a whole set here so I never have to pay three times as much locally. WD40 did the trick. No more noise ☺ Quote Link to comment Share on other sites More sharing options...
