Let's talk rear struts!
sampuppy1
Seems like these always get ignored.
What do you have?
What have you had?
What do like/hate about what you got?
Buy complete/build your own?
Best options for stock daily drivers? Racers? Street/strip?
I've got a stock 2000 Regal GS. No plans to race. Found monroe quick struts which from what I saw is the sensatrac line. Complete. Gonna give them a try.
Sent from a flagged XT1254
Tyler/T-Unit
Monroe is junk. I have em both on my Cutlass and G20. They wear out quick. Expect to change em in 2 years. 5 if you get lucky. I vouch for the KYB's
I never considered KYB "performance". I have a KYB strut on the drivers side and a Monroe on the passengers side of my Infiniti and I couldn't tell the difference until the Monroe side shot out . The ones on the rear are both Monroe as well. Waiting for them to go bad too.
KYB GR2/Excell G and Monroe Sensatrack/OESpecturm are considered OEM replacment, both manufacture for OEMs. I've run both over the years, I have no real preference both have delivered long life and worked as intended.
My z34 has some long, long discontinued Koni's in the rear, had them rebuilt for a large sum of money at one point.
For a 2g About the only performance strut available is a KYB AGX. They are quite a good deal for what they are
I found a set of monroe rears for a great deal so I'll probably just get them. If they blow apart, I'll get different ones.
Tyler/T-Unit
  • 3 weeks later...
What ever the stock ones are in these cars are pretty good i think. They will lean alot when turning but thats easily fixable with a STB. Otherwise they soak up everything pretty well.
They make bilstein for the W body I have new ones I will install on my 2001 Regal
I can't find anything for it. Where did you get them?
I have a front STB. No rear.
I ended up getting Monroe quick strut assemblies. They ride nice. Not very noisy.
If I can find bilsteins complete I'll do them up front for sure.
Tyler/T-Unit
  • 1 month later...
Based on the recommendations here, i just installed the KYB GR2 on my 1995 Cutlass Convertible. I am VERY pleased after a couple of initial test drives. My car only has 49,000 miles so i wasn't sure how worn out they could be....these made a HUGE difference. Obvious how worn out mine were now.
Thanks for the advice.
  • Like 1
