pitzel Posted June 2, 2016 Report Share Posted June 2, 2016 The spring seat failed on my car while driving in rural Montana last week. I ended having to pay someone to pull the entire strut tower/spring assembly from a junkyard vehicle to get it back on the road (after an expensive tow job!), but now I'm kind of worried about the other side. The car itself doesn't have much rust otherwise, and this failure was in an undetectable/uninspectable part of the vehicle. 1) Can you buy just the seat and install it? What's the part number and where would I get one? 2) Any way of inspecting it? Anyone else run into this problem? Car doesn't have many miles on it (~150k), and they don't use that much salt here. Kind of frightening. Glad it happened on a highway that I could pull over relatively easily, in the morning, without damaging the tire too badly. Quote Link to comment Share on other sites More sharing options...
Schurkey Posted June 2, 2016 Report Share Posted June 2, 2016 What I see is a failed strut assembly--not the strut tower. Am I missing something? Quote Link to comment Share on other sites More sharing options...
pitzel Posted June 2, 2016 Author Report Share Posted June 2, 2016 f What I see is a failed strut assembly--not the strut tower. Am I missing something? Maybe I'm using the wrong terminology? The fractured piece is definitely not part of the front strut cartridge -- its the spring seat. Basically the bottom line is, can I replace just that part on the other side (which is probably corroded as well)? Quote Link to comment Share on other sites More sharing options...
pitzel Posted June 2, 2016 Author Report Share Posted June 2, 2016 Err, you got me doing more searching. Turns out the part is SM5383 / SM5384 for KYB, ie: spring seats. Not that it would have changed the outcome, but I never knew such parts existed till now. Bleh, a whole ton of work I guess. But at least I can do everything without a junkyard visit. Quote Link to comment Share on other sites More sharing options...
pitzel Posted June 2, 2016 Author Report Share Posted June 2, 2016 Any way of replacing that spring seat without pulling the whole assembly (ie: undo ball-joint, brake parts, tie-rod, axle nut, 3 bolts at the top), and using spring compressors? Quote Link to comment Share on other sites More sharing options...
White93z34 Posted June 2, 2016 Report Share Posted June 2, 2016 No sir. Can't say I've ever seen a strut mount/spring seat fail in that manner before. Quote Link to comment Share on other sites More sharing options...
rich_e777 Posted June 2, 2016 Report Share Posted June 2, 2016 f Maybe I'm using the wrong terminology? The fractured piece is definitely not part of the front strut cartridge -- its the spring seat. Basically the bottom line is, can I replace just that part on the other side (which is probably corroded as well)? I have a pair of those seats from KYB and they also come with the spring seat bushing which you will need as well as the strut bearings which sits just under the tower mount IIRC. I can get you the KYB P/N for the bearings when I get to my shop. (Un)fortunately everything has to come out to do the job right but then the job is done right and there shouldn't be an issue there for a long time. Quote Link to comment Share on other sites More sharing options...
Heartbeat1991 Posted June 2, 2016 Report Share Posted June 2, 2016 The spring perches are easy to get. You will have to disassemble the entire strut. It's no picnic. I just did them yesterday. I have an NOS perch stashed away. The shape of the perch makes it difficult to line up the spring compressor. But it's doable. It's really not that bad to do. Parts are pretty affordable for it too. Quote Link to comment Share on other sites More sharing options...
Heartbeat1991 Posted June 2, 2016 Report Share Posted June 2, 2016 http://www.rockauto.com/en/catalog/pontiac,1990,grand+prix,3.1l+189cid+v6+turbocharged,1255621,suspension,coil+spring+seat,10444 Quote Link to comment Share on other sites More sharing options...
Padgett Posted June 2, 2016 Report Share Posted June 2, 2016 (edited) Oh drat, just realized that is the bottom of the spring perch and not the strut mount (top) & the broken part is sitting on the tire. Yes, that is a bolt in replacement but I also always change the strut mount (bearing at the top of the strut) any time out. When worn it can squeak randomly and drive you bonkers. Edited June 2, 2016 by Padgett Quote Link to comment Share on other sites More sharing options...
GOT2B GM Posted June 2, 2016 Report Share Posted June 2, 2016 Neato Heartbeat1991 1 Quote Link to comment Share on other sites More sharing options...
Heartbeat1991 Posted June 2, 2016 Report Share Posted June 2, 2016 Oh drat, just realized that is the bottom of the spring perch and not the strut mount (top) & the broken part is sitting on the tire. Yes, that is a bolt in replacement but I also always change the strut mount (bearing at the top of the strut) any time out. When worn it can squeak randomly and drive you bonkers. These cars don't have a bearing. Just a bushing. And it's very easily changed out from under the hood. Quote Link to comment Share on other sites More sharing options...
Padgett Posted June 2, 2016 Report Share Posted June 2, 2016 OK now I am confused It looks like (4) rubs on (2) and the three ball bearings on my E-bodies have gone away. Further what broke is (7) and (8). Correct ? Is (33) the replaceable bushing ? Quote Link to comment Share on other sites More sharing options...
55trucker Posted June 2, 2016 Report Share Posted June 2, 2016 These cars don't have a bearing. Just a bushing. And it's very easily changed out from under the hood. hmmmm, you sure about that Dan? the bearing is in the center of the spring seat pressed into the seat, when one replaces the seat a new bearing will be in there. the rubber isolator sits around the bearing assembly and hides the bearing from view. On this design the spring is always stationary, the lower end of the strut swivels. Quote Link to comment Share on other sites More sharing options...
Schurkey Posted June 4, 2016 Report Share Posted June 4, 2016 Subscribed, because my '92 has stiff steering, and some memory. I suspect the bearing(s) are seized or nearly seized. I'll be dicking with it some time in the future. pitzel 1 Quote Link to comment Share on other sites More sharing options...
Heartbeat1991 Posted June 4, 2016 Report Share Posted June 4, 2016 hmmmm, you sure about that Dan? the bearing is in the center of the spring seat pressed into the seat, when one replaces the seat a new bearing will be in there. the rubber isolator sits around the bearing assembly and hides the bearing from view. On this design the spring is always stationary, the lower end of the strut swivels. There's no bearing in the seat. Just a rubber isolator. I have an NOS seat brand new in my hands. It doesn't even have an isolator on it Just a stamped steel seat with a rubber spring isolator. I just had them all apart on Galen's car. No bearing. It seems that it just slides on the spring seat. Quote Link to comment Share on other sites More sharing options...
55trucker Posted June 4, 2016 Report Share Posted June 4, 2016 ^ I'm going to assume that the seat that was purchased is *sans* bearing. wouldn't B.S. you Dan, there is a bearing that sits in the lower seat. Heartbeat1991 and rich_e777 2 Quote Link to comment Share on other sites More sharing options...
GOT2B GM Posted June 5, 2016 Report Share Posted June 5, 2016 I can also confirm, there is a the above mentioned bearing in the bottom of the lower spring perch. Quote Link to comment Share on other sites More sharing options...
Heartbeat1991 Posted June 5, 2016 Report Share Posted June 5, 2016 Sounds just like GM to sell the perch without the bearing. I guess I'll need to track down a bearing for it somewhere. It wasn't making sense to me that there'd be nothing there to isolate the movement. But there wasn't anything there when I opened the box. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted June 6, 2016 Report Share Posted June 6, 2016 I really want to look now, for the life of me I cannot picture a bearing under the springs, just a rubber thing that is molded to hold the spring. Not saying it's not there, perhaps I never looked under the rubber thingy? Quote Link to comment Share on other sites More sharing options...
Heartbeat1991 Posted June 6, 2016 Report Share Posted June 6, 2016 It's in the center where the seat rides on the strut assembly. Not under the spring isolator. Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted June 10, 2016 Report Share Posted June 10, 2016 The bearing sits between parts #8 and #9 on Padgett's diagram. I managed to get smooth motion out of a bearing by squirting some oil into it using an oil can. I guess they're not sealed that well. It's not a bad job, but you definitely need to compress and remove the spring, so if you have any interest in replacement lowering springs, now would be the time to install them. Quote Link to comment Share on other sites More sharing options...
Padgett Posted June 10, 2016 Report Share Posted June 10, 2016 Really, no-ne has a FSM ? Guess that is why they were so cheap on evil Bay. 1993 W FSM page 3C1: Quote Link to comment Share on other sites More sharing options...
