Cutlass Supreme **2 door** headlamp mount panel
l2bengtrek
Hello All!
It's been a while.  I own a 94 Cutlass Supreme convertible that had a fender bender. I'm in big need of a headlamp mounting panel for it and I'm having a REAL hard time finding a replacement.  It seems that nowadays, not only are the convertible parts hard to find..the 2-door models are too! (At least here in the Cincinnati, Ohio area)  Does ANYONE have any suggestions on where to find one or does anyone here have one to sell?  Again, its the 2-door variation with the quad headlights.  pretty sure '93,'94,'95 are all the same.  THANKS for any help with this matter!  Scott
I kick myself for not grabbing the header panel off the last coupe I came across, I was in the same situation for awhile a few years back. If I come across one I`ll start collecting them.
The Louisville, Ky Pull A Part shows a 1996 2 door on the lot. A 1994 is listed, too, but isn't showing whether it is a sedan or a coupe. A couple hour drive from Cincinnati, but maybe worth the trip.
Www.pullapart.com
Are you needing the bumper cover, headlight bezel, and all the stuff from the front?  Were you at? we have typical regular 2 door cutlass show up here
I just need the mount panel.  The hood took most of the damage...the bumper cover is good. I'm in Cincinnati, Ohio  Although, a good passenger side bezel would be good...mine got nipped on the inside corner a little.. let me know! Either here, or PM. Thanks!
