oz37k Posted December 23, 2013 Report Share Posted December 23, 2013 Hello All, I have a 1995 MC Z34 which has a screaming a/c clutch bearing and not even worth spending the extra $$ to full fix my non functioning a/c. Hasn't worked for the past 6 years. I have been searching web and this site and have found that Dorman make a bypass pulley #34197. Has anyone used this on their LQ1 car and does it work. I plan to take my car to my friend's shop to get it vacuumed out so that there are no surprises when I disconnect the lines. Any input would be appreciated. I would like to do this before my engine seizes. Thanks. Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted December 23, 2013 Report Share Posted December 23, 2013 I could be wrong, but having something on the serp belt wouldn't seize an engine, it would rob power and maybe eat a belt However, I'm also curious to know because I currently have 2 LQ1 engines with non working AC, although I hope to have one working next summer, and maybe the other going this route Quote Link to comment Share on other sites More sharing options...
oz37k Posted December 23, 2013 Author Report Share Posted December 23, 2013 I could be wrong, but having something on the serp belt wouldn't seize an engine, it would rob power and maybe eat a belt However, I'm also curious to know because I currently have 2 LQ1 engines with non working AC, although I hope to have one working next summer, and maybe the other going this route yeah, sorry meant compressor seizes. my bad. Quote Link to comment Share on other sites More sharing options...
RobertISaar Posted December 23, 2013 Report Share Posted December 23, 2013 if/when the compressor seizes, expect to have a worthless belt in about 2 seconds. at that point, you'll obviously have no water pump, alternator or power steering either. won't seize the engine unless you kept driving it longer than the time it takes to pull off the road and swear at the compressor. Quote Link to comment Share on other sites More sharing options...
Schurkey Posted December 23, 2013 Report Share Posted December 23, 2013 You're saying that buying a "delete pulley" costs less than buying a pulley bearing? Hey, it's your car, but why drive a deteriorating junker when you could just fix it--or have it fixed--and enjoy the A/C? Quote Link to comment Share on other sites More sharing options...
oz37k Posted December 30, 2013 Author Report Share Posted December 30, 2013 ok. so I ended up getting the delete pulley but I noticed that the hardware included is not for my LQ1. Does anyone know if I can reuse the old hardware and add a nut and washer to hold pulley in place? Quote Link to comment Share on other sites More sharing options...
Heartbeat1991 Posted December 30, 2013 Report Share Posted December 30, 2013 You're saying that buying a "delete pulley" costs less than buying a pulley bearing? Hey, it's your car, but why drive a deteriorating junker when you could just fix it--or have it fixed--and enjoy the A/C? The bearing probably costs less than the delete pulley did. I have done a couple AC bearings. The bearings are like $20 or so as I recall. Quote Link to comment Share on other sites More sharing options...
oz37k Posted December 30, 2013 Author Report Share Posted December 30, 2013 The bearing probably costs less than the delete pulley did. I have done a couple AC bearings. The bearings are like $20 or so as I recall. Yeah but the compressor is gone, leaks all over. I don't want to spend to take off the compressor, put the bearing and still have a non-functioning compressor plus I heard you need special tooling if I am not mistaken. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted December 30, 2013 Report Share Posted December 30, 2013 ok. so I ended up getting the delete pulley but I noticed that the hardware included is not for my LQ1. Does anyone know if I can reuse the old hardware and add a nut and washer to hold pulley in place? Mine for the L67 came with strange hardware too, but the shape was right so I just used the old compressor bolts. Quote Link to comment Share on other sites More sharing options...
RoyalRegal Posted December 31, 2013 Report Share Posted December 31, 2013 Those delete pulleys are absolute garbage. I put one in my Regal and you could see a noticeable wobble from it. The first tip off is that the pulley is friggin plastic. The back plate that bolts onto the engine is metal, but that is where it ends. My Ciera's compressor went bad last summer thanx to the PO doing a piss poor R34 conversion, but thankfully the bearing inside is OK and Im able to just leave it alone without needing to remove it. Quote Link to comment Share on other sites More sharing options...
Schurkey Posted December 31, 2013 Report Share Posted December 31, 2013 Those delete pulleys are absolute garbage. Sometimes folks just have to learn for themselves. Quote Link to comment Share on other sites More sharing options...
tornado_735 Posted January 1, 2014 Report Share Posted January 1, 2014 I've had 3 different delete pulleys on three different General Motors vehicles, and I never had a problem. Jesus Christ...you'd think by the responses here that he wanted to delete power steering and power brakes. :roll: Quote Link to comment Share on other sites More sharing options...
oz37k Posted February 17, 2014 Author Report Share Posted February 17, 2014 UPDATE: Installed bypass pulley, 3 days and still holding up after long drives. My compressor was seizing up. Quote Link to comment Share on other sites More sharing options...
tornado_735 Posted February 18, 2014 Report Share Posted February 18, 2014 I've put multiple thousands of miles on these delete pulleys with no problems. You should expect similar results! Sent from my Nokia Lumia using Tapatalk Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted February 18, 2014 Report Share Posted February 18, 2014 I'm still tempted to get one and ditch the AC completely, since I probably wont bother ever fixing it Quote Link to comment Share on other sites More sharing options...
oz37k Posted February 18, 2014 Author Report Share Posted February 18, 2014 I've put multiple thousands of miles on these delete pulleys with no problems. You should expect similar results! Sent from my Nokia Lumia using Tapatalk Yeah, holding up well. I notice that the engine does not have the drag it had. Good thing I took out the compressor cause my mechanic showed it to me and it seemed that the pulley was going to fly off at any minute or weld itself from spinning with no bearing. Quote Link to comment Share on other sites More sharing options...
will_s95 Posted February 18, 2014 Report Share Posted February 18, 2014 Mines had a pulley ever since I bought it. I wish it had a compressor... I have put about 15k on the car, who knows how long the previous owner had it in there. Old lady who "didn't like to be cold." plastic pulley and everything. No problems. Quote Link to comment Share on other sites More sharing options...
tornado_735 Posted February 21, 2014 Report Share Posted February 21, 2014 Yeah, holding up well. I notice that the engine does not have the drag it had. Good thing I took out the compressor cause my mechanic showed it to me and it seemed that the pulley was going to fly off at any minute or weld itself from spinning with no bearing. I had an AC compressor pulley seize solid one morning. The starter couldn't even turn the engine over. It was bad. Quote Link to comment Share on other sites More sharing options...
