Can I put a washer fluid pump from a '95 into an '03 . . .
Breakdown
The reason that I axe is that I just bought and installed one of these about Novembuary 25th, and since that time my car's been down for a period of time and we've had good weather as well.
Well the stupid F-F-F-U-U-U- thing is broken again. I'm so tempted to rip the new (old) one out and throw it through the window of Part Source. So I'm not really interested in building another Chinese piece of S*** so I have Jamie's old one from his '95 can I just put that in AJAM??? It's not the cost of the part, it's just having to do it again and again, I can't really hear it trying to work and I did try doucing the jets with hot water without any luck.
Oh BTW - I'm just pissed in general. There's no need for this. Also why can't GM join the 21st century and use the hood-mounted types they can use heat from the hood to warm up so they don't freeze as much??
Are you sure the pump is the issue if you can hear it running?
The jets in my truck are frozen solid right now...... pump is fine
Cannot hear it running.
Usually I can.
