Crazy K Posted February 27, 2006 Report Share Posted February 27, 2006 ...when I am able to pull forward into my driveway, I move my gear selector from park to drive, shouldn't the transmission being in drive prevent the vehicle from rolling backwards? This is just at idle, not talking about anything over 900 rpm here. no, it would not. need I elaborate? the hill is steep enough to overcome the idling car in drive. It will probably do the same when the car is warm if you did the same thing. Can someone elaborate on weaken tranny pump details? it may be a problem one of my cars has. my 91 vert won't go unless pushed in gear or lifted, operated in gear while in the air, and then dropped... It can even be off when dropped, it's just the very first time you try to move the car cold. Quote Link to comment Share on other sites More sharing options...
White93z34 Posted February 27, 2006 Report Share Posted February 27, 2006 so your saying that if your in drive and on a hill with the nose faceing up it will roll backwards if you let off the brake? if thats what your asking then, its perfectly normal for it to do that. mine does. Quote Link to comment Share on other sites More sharing options...
slick Posted February 28, 2006 Author Report Share Posted February 28, 2006 Alright, thats what I assumed. Just seemed wierd that in my mom's '97 Avalon, her vehicle doesn't roll backwards. Quote Link to comment Share on other sites More sharing options...
chadz34 Posted February 28, 2006 Report Share Posted February 28, 2006 so your saying that if your in drive and on a hill with the nose faceing up it will roll backwards if you let off the brake? if thats what your asking then, its perfectly normal for it to do that. mine does. It depends on how steep the hill is, it shouldn't roll back if it isn't that steep, it should stay still. If it is really steep then it will roll back. Quote Link to comment Share on other sites More sharing options...
