95whitevert Posted May 16, 2017 Report Share Posted May 16, 2017 Grrr, so I notice after I finished up topping off the Freon (getting to need the a/c now) that I might have pulled out a connector. It is connector PED 19 and for the life of me, I can't seem to figure out where it goes. The MAS connectors look right, so I am not sure where this goes. I have the 3.4l engine. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted May 16, 2017 Report Share Posted May 16, 2017 Wire colors? General location? Quote Link to comment Share on other sites More sharing options...
95whitevert Posted May 16, 2017 Author Report Share Posted May 16, 2017 See attached picture. The connector comes out of the wires containing MAS and air intake connectors so my guess it has something to do with the air intake system. Quote Link to comment Share on other sites More sharing options...
Imp558 Posted May 16, 2017 Report Share Posted May 16, 2017 That was already loose, it's a fuel pump prime connector. Check continuity to the pins beneath the fuel pump relay to verify but I'm like 99% sure. 95whitevert 1 Quote Link to comment Share on other sites More sharing options...
rich_e777 Posted May 16, 2017 Report Share Posted May 16, 2017 Yup its suppose to be loose. Its like that on both my Olds. Your good. 95whitevert 1 Quote Link to comment Share on other sites More sharing options...
95whitevert Posted May 17, 2017 Author Report Share Posted May 17, 2017 YAY! Thanks for the info. BTW I just put the convertible back on the road. It has been about 2 years since I driven it more than a couple of miles. Completely re-did the underneath, replaced the fuel lines, gas tank, brake lines and removed about hundred pounds of rust from everything else under there and then coated the entire bottom. Replaced the rear window moldings, got the interior lights working, fixed the windshield molding and replaced the antenna. Hopefully that keeps her on the road for a few more years. While she isn't 1969 Cutlass, I see more of them on the road than I do my 1995 Nas Escobar, primergray, Imp558 and 2 others 5 Quote Link to comment Share on other sites More sharing options...
primergray Posted May 17, 2017 Report Share Posted May 17, 2017 I've been wondering about that connector...but apparently not enough to ask about it... Quote Link to comment Share on other sites More sharing options...
Imp558 Posted May 17, 2017 Report Share Posted May 17, 2017 If you power it up the fuel pump will come on.It goes to the normally closed terminal on the relay. Quote Link to comment Share on other sites More sharing options...
