Front Knocking Noise
94RegalLimited
 Share
Hello all! Just joined this lovely forum about 2 minutes ago! Im looking for some suggestions as to what a knocking sound from my front passenger side is. I drive a 1994 Buick Regal Limited. I have a video linked below with the sound. I have felt around while a friend pushed on the car and I can't seem to pinpoint it. It feels strongest on the strut but still not what I'd expect from how loud the sound is.
Heres the link ---
My struts where bad many months ago so its a good possibility thats it, so I just ordered new Monroe cartridges and the tools i need, but I'm only like 50% sure that will solve it, any ideas?? Thank you!!
Link to comment
Share on other sites
Also when I'm driving at low speeds it rattles, and doesn't do much when i'm accelerating and slowing down. Also it doesn't change much when I'm turning. Thanks again!
Link to comment
Thanks for the quick replies!
Sorry thought it was idling. If not my thought its the CV joint. Normally worse when driving in tight circles at full lock.
Haven't tried driving in tight circles at full lock yet, I will try that before I leave work today!
That sounds further inboard like a swaybar bushing or something. It's got a bit of a creak too.
I grabbed the sway bar with my hand while a friend moved the car, and I felt the creak coming from that but no knock vibration whatsoever, so I don't think its coming from the sway bar
Also just noticed this morning it doesn't seem to be effected by acceleration and braking, only at certain speeds and bumps in the road.
Link to comment
That is really pronounced. I was going to suggest lower ball joint but I don't think that ever gets that bad. It just rips off at that point. It's like you have a completely missing LCA bushing on the other side. Are you sure the noise is from the viewed side?
One isolation trick may be to disconnect the sway bar from one side.
Link to comment
SOLVED!!! Sorry for no reply but it was just the large nut that holds the strut cartridge in place.... This one
Was completely loose! Thanks for all the help!
  • Like 1
Link to comment
Good work reporting back. Glad you figured it out.
Link to comment
Autozone had the proper tool for rent for free when I did mine... They give you 30 days too.
Do they still rent that? My local ones don't have the tool anymore.
Sent from my Moto G4 Plus using Tapatalk
Link to comment
I used an offset wrench and an allen / 6mm hex bit that i could attach to my breaker bar to get it tight. I tried to use an allen key made in china first and it just broke on both sides.
Link to comment
What about tightening the part that was actually your problem though? You said the retaining nut was loose, not the top nut.
I used something similar to this:
https://www.amazon.com/OTC-4533-Stinger-W-Body-Strut/dp/B00063Y156
It was loaned out from autozone but I am not sure they still do that. I imagine one can get to it from underneath with a big enough pipe wrench though.
Link to comment
the allen/offset socket is used to secure the top of the strut piston to the upper bumper assembly,
the cartridge is held in place by the large male threaded retaining nut that is at the top of the strut opening. I take it that the retaining nut is what was causing your problem and you have secured THAT nut to the strut.
Link to comment
  • 4 weeks later...
AutoZone no longer carries the W-body strut tool. I bought the AmPro tool because I some people said the OTC one didn't always fit aftermarket struts well, but it's more expensive.
Link to comment
 Share
