04 Impala SS Indy 500
tomtom123
I bought an engine and transmission from a 2004 Chevy Impala SS Indy 500 Edition.
The engine I put into my 99 Grand Prix GTP.
I was told that my GTP has a different transmission than the Impala.
Now, I have found no info on any differences. The only obvious difference is the range selector switch that my GTP has isn't something the Impala came with.
Is there any info anyone has on the differences between the 99 GTP transmission and the 04 Impala SS?
just gotta use the neutral safety switch from ur old tranny
The electronics are different in the 2003 and up 4T65e and will not work with the '02 and back PCMs. If you want to use the transmission out of the Impala in your '99 GTP, you need to get a PCM for an '03-05 car that is compatible with 03-05 L67 programming.
'04 tranny has the range switch internal. Either a PCM as chevelle said or you can "piggyback" the
4 wires from the 4 pin connector on the range switch to wires on the main tranny connector.
Otherwise, the tranny won't shift out of first gear.
I apologize for not being able to tell you the correct wires. It's been a while since I've done one.
If I get a minute, I'll look it up.
easier way would b to do what i did on my car.
car97 monte
trans 01 monte ss
harness 98 monte z34
engine 97 l67
pcm 99 gtp
nss(or range selecter) 02 gp gt
what 95 vert said about internal switch is dead on, but the shifter shaft and trans case is the same as any 4t65
i just slapped the switch from the 02 gp on, plugged it in and took off, no spliceing no diagrams etc etc. plus keeps replacement tranny options open
Maybe I read it wrong, the 04 you said has the selector switch?
My 04 Impala transmission doesn't have the range selector switch, however my 99GTP does.
That's a dirty pic of my 04 Impala transmission
Does the range selector switch allow the transmission and car to talk? Or does it just read where/what gear the transmission is in?
So just to clarify, tom tom could stick the correct range selector switch from his '99 GP on the 2004 transmission and it would work with the stock '99 electronics without other modifications?
