Shift kit question???
Cali boi
Hey guys its been a long time. I have a question on some of the shift kits I found and want some input you guys. So I found for the 4t65e tranny was the thrasher, trans go, and the ZZP. I not sure on which i should get so I did a bit of research and found that the trans go, and the thrasher shift kits are both the spring type and the ZZP is a valve type (not to sure what to call it). So seeing that i was thinking if or will it be ok to run the thrasher or trans go with the ZZP. And if not a good idea which would be the better one to go with..
Sent from my iPhone using Tapatalk
