03+ series 2 3.8 power curve?
l67ss
ive read that they started installing heads with better ports and larger valves in 03+ 3.8s (that were still series 2) yet they still have the same 200hp rating. did the head swap affect the power curve w/o raising power peak? curious as im getting an l36 from an 04 impala thanks :)
well, i have something, but it doesn't look very good.... pulled from a 96 camaro VIK.
http://www.gmheritagecenter.com/gm-heritage-archive/vehicle-information-kits.html
you may find something better there?
i find it hilarious how the F-body rates lower than all of the FWD applications....
as for early vs late, they look similar, but not identical. early shows much better output at lower RPMs, but peaks are the same. knowing GM, i expect there to be some manipulation of reality going on in the earlier chart.
answered my question :)
That torque curve is flat as shit.
at first glance, yes,but it starts dropping off badly after ~4200 or so.
now compare it to an engine that was generally put in the same vehicles.
it doesn't suffer anywhere near as badly.
more analysis: looks like they both end their plots around 180 lb-ft. the 3400 is at ~5600RPM, while the 3800 is around ~5800RPM.
so, a 3400 at 5600 = a 3800 at 5800. bring the revs higher and then the lowly little 3400 actually overtakes the 3800.
oddly enough, i don't have a L67 chart in my archive.....
All I can add to this, is that the 3400 sounds good shifting at 6800rpm :D
Yeah I am gonna miss the sound of my 3.4, punched it to pass someone touched 105 MPH the sound was almost sex lol
  • 3 years later...
